    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 112
    1. #61
      Dec 2007
      OK some conclusions.
      It appears for my current setup to work I would need to shorten the steering arms, replace upper control arms and modify the lowers.
      Alternatively I can get wheels with 4 7/8" offset, then use 2.5" shorter upper and lower control arms then I believe the spindles would work.
      This would decrease hub-hub width to 50" which eliminates most power steering racks. I think the woodward rack will work with 50".
      I guess thats what I need to determine next, I am trying to keep power steering, that is part of the reason for this exercise.
      Thanks for all the help so far!
    2. #62
      Oct 2009
      New Derry, PA
      Keep in mind that if you go with a lower offset wheel, the tire will "swing" further toward the fender as you steer. Make sure you have adequate outside clearance if you go that route.
    3. #63
      Woodstock, Ga
      I was trying to find one of my notebooks I have of suspension measurements and drawings and it seems to be boxed up somewhere. I will try to sort through some of my cad files to pull the measurements, but you may be able to find some of the information you need in the links below if your interested in the c5/c6 suspension parts at all.
      Looks like the upper arm is 8.55 and the lower is 15.96
      https://www.pro-touring.com/showthre...n-measurements
      http://www.vettemod.com/forum/showthread.php?t=8387
      http://www.gt40s.com/forum/gt40-tech...int-taper.html
      Robert
    4. #64
      Dec 2007
      Hey man thanks for the links, just went through those.
      I had found those dimensions for the C-5 arms, looks like that gives about 140%
      difference for the set.
      On the S10 control arms its closer to 125%.
      I came across this last night, was a very interesting blog I read the whole thing
      last night finished it about 3am
      http://www.rhoadescamaro.com/build/?m=201211
    5. #65
      Woodstock, Ga
      Rick, are you able to make arms? you could always use the vette knuckle and make both or one of the arms. There are also a few companies that might be able to make you custom length arms.
      If you do go the blazer spindle route, and need to get lower, I have a new pair of 2" drop spindles with new sealed hubs and corvette brakes bracket I bought several years back.
      Robert
    6. #66
      Dec 2007
      [QUOTE=RS_Customs;951658]Rick, are you able to make arms? you could always use the vette knuckle and make both or one of the arms. There are also a few companies that might be able to make you custom length arms.
      Hey robert, ideally I would like to get all these dimensions put in a suspension analyzer program by someone who is familiar with it to discuss what it says and
      go from there. I don't have a source for someone to make arms but have not researched that route yet, what about you?
      At this point no decision on any parts, need to find correct dimensions then see what I need to put it together, where that tie rod end needs to be etc etc,
      I am not sure what specifications are still needed to plot this all out
      I think after reading the rhoades build I want 5-10 degrees of caster and camber and
      I believe the control arm ratio should be closer to 150 than 125 which would give me
      control arm lengths like 14 inches on the bottom and 7-8 inches for the upper.
      The vette lower arms are almost 16 inches with an upper around 8.5, I don't
      believe I have room for 16 inch lower control arms and have room for exhaust
      and steering.
    7. #67
      Dec 2007
      OK so I downloaded the demo and put some points in....
    8. #68
      Dec 2007
      In this plot I basically narrowed the 2001 Corvette specs 7 inches. In doing this I lost 3.5 inches
      off of each lower control arm thus changing the effective rates. Did not seem to have a huge
      difference.
      LINES EDITED WERE:
      Upper ball joint
      Upper frame pivot front
      Upper frame pivot rear
      Lower ball joint
      Lower frame pivot front
      Lower frame pivot rear
      Tie rod on Rack
      Tie rod on Spindle
      Track width
      Tread width (for larger tire)
      Camber
      2001 Corvette specs
    9. #69
      Oct 2009
      San Diego, CA
      Saw this thread as a link referrer...
      If you're going this clean sheet man, why not put the engine behind you? Mate it up with a G50 or Sierra transaxle depending on power levels. Then you'll have all the room to do anything you want with the front suspension, manage cooling better, and best of all - you'll have a much lower polar moment and a much higher static rear weight distribution, than any of these crappy old musclecars people are building. All these builds with a bajillion HP going through crappy 200TW tires, ugg - at least with ~60% static on the rear 345 tires, you'll have a chance of putting some of it down.
      Also, I wouldn't use those parts - the circle track catalogs have lots of stuff to choose from that isn't as expensive, and will offer a lot of adjustability to help with tuning down the road.
    10. #70
      Dec 2007
      Hey thanks for the reply. I suspect most of this was sarcasm, since this is a vega after all, not another high dollar
      first/second gen camaro build. Regardless I respect what you are saying after reading your blog and the CVD series.
      This is all Marcus at SC&C's fault.(totaling j/k) My plan was to just bolt on some control arms and fit some larger tires, but then
      after speaking with him about the pitfalls of the stock front suspension, well here we are.
      Any advice you have to offer here would be greatly appreciated, outside of moving the motor to the back of the car.
    11. #71
      Dec 2007
      Quote Originally Posted by exwestracer View Post
      I have to agree with Donny on this one. A few years ago we did a frame for an S10 that used C4 front suspension, and the control arm mounts literally wrapped around the small-block engine.
      Attachment 67413
      Attachment 67414
      Attachment 67415
      There's a reason a lot of projects still use MII architecture...
      Hey Ray, I was looking at this picture again, what I notice is it looks that that truck has wheels with
      4.5 inch backspacing. Is that correct?
      If I set this up with the Vette Wheels with backspacing of 7.38 inches that will gain me 5.75 inches
      to move the control arms out, about 2.75 inches further out on either side from what is in these
      pictures right?
      Do you recall what the outside frame width was on the S10 chassis?
      Thanks.
      A pic to show I am getting it read for new frame rails...
    12. #72
      Oct 2009
      New Derry, PA
      Sorry, I don't remember ANY details about that truck, other than it was a real PITA to package everything.
      Looking at the first picture, the frame support fixtures are almost exactly 1/2 way out on the frame bench crossmember. I measured one and they are 49 1/2" wide, so that would put the frame rails somewhere ABOUT 24-25" on center. Hope that helps.
    13. #73
      Dec 2007
      Picked up my C5 suspension pieces and did a little more measuring, cutting, welding and this is where I got...
    14. #74
      Sep 2007
      Buford, GA
      I'm sure this is a silly question, but you do plan on tying the front of the sub back up to the top of the firewall, right?
      Adam
      1985 S10 - LT1 + T56
    15. #75
      Sep 2007
      Buford, GA
      Okay, here is what seems to be a logical next step. I think you should make a drawing from the SIDE of the car plotting the points you know about where the UCA's and LCA's should mount. At least in the "X" and "Y" direction. Don't even worry about the "Z" direction for my example. Doing so you will be able to locate the height (top and bottom elevation) of your frame rail. Obviously you don't want to have your framerail too high and not be able to get your UCA mount low enough to locate it correctly.
      Adam
    16. #76
      Dec 2007
      The steering rack should be here this week, also ordered some threaded tube ends for the lower control arm mounts, I need to get the upper
      control arm brackets made so I can get those mocked in. The place I have been getting steel from has a laser cutter if I can send them a dxf
      or dwg file they can cut them out for me.
      The pictured with the control arms clamped to the frame is roughly at ride height, 6 inches from rails to ground, top of kicked up rail 15.5 inches
      if I remember correct. Concern now is if there is really room for the motor between those rails....
    17. #77
      Oct 2009
      New Derry, PA
      In FRONT view, is the LCA mounting bolt level with the lower ball joint center? A straight on front picture of your mockup would help to see the relative angles.
    18. #78
      Dec 2007
      More or less, according to performance analyzer the LCA front and rear pivots are not level and the ball joint is 6.375 inches from ground. That is a 2x6 channel those threaded rods
      are sitting on. so roughly 6.25 ish i would say, I am just mocking things up to see if it will work or not, taking measurements etc. I will lower the frame back down
      and do take some pics with measurements...
      In looking at the A arm geometry from the factory there is 12.625 inches between front upper and lower pivots and 10.625 inches between the rear upper and lower pivots
      Also, the lower arm is pitch up from front to back and the upper is pitched down from front to back.
      Factory spec is nine degrees of caster, I would like to lower that to 6 degrees so I was thinking of raising the rear upper pivot about .46 inches, to decrease
      the caster, is there an adverse condition I will be inducing by doing this? Do I need to move something else in addition?
      I used to do front end alignments, part time job at Sears when I was in school, so I know a little about front end geometry but this is getting deeper....
    19. #79
      Oct 2009
      New Derry, PA
      Raising the pivot won't change the static caster. It will change the amount of front brake anti-dive and caster GAIN. Shifting the UCA mounts forward in the chassis will reduce the static caster.
    20. #80
      Dec 2007
      ok, so armed with a little info looks like if i move the upper control arm mounts forward .375 inches it should lower the caster to approximately 6 degrees.
      I was thinking, when we did alignments of course we could not move the pick up points forward or backward or up or down, to add subtract caster you
      had to stagger the upper shims if I remember right.
      I think its coming together, I should have a rack in this week so thats the next and probably biggest part of this puzzle to come.
      Thanks for all the help. I am trying to push my knowledge this is the biggest project I have taken on.
      Rick
