    Results 1 to 20 of 24
      Jun 2010
      Deployed
      HELP! Custom Radiator Hose
      Gents,
      I have searched the web over and over again...Contacted Dayco....No progress..
      I need a custom radiator hose. The Intake covers up the area that prevents the stock LS1 hose to be used...Trying to avoid expensive options like Cool Flex.
      I need help. Someone has to know someone who forms hoses.
      1970 Camaro/DSE build
      Sep 2007
      Southern California
      can you use a piece of stainless tubing with short pieces of hose at each end?
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
      Jun 2010
      Deployed
      Jun 2010
      Deployed
      Help..Help..Help....
      I know there are a lot of customize rs our there...
      Jul 2009
      Grand Rapids, MI
      I would say stainless tube with short hoses at the ends for your curves. Or take your mock-up hoses to someone who can bend stainless tube to match.
      Will Ellis
      Build Thread
      Jun 2010
      Deployed
      Quote Originally Posted by wellis77 View Post
      Well after contacting a half dozen so called hose companies, nobody seems to want to help me as they promise to get back with me and never do....I had to go against my feelings and bought a cool flex hose. Its already been nearly two months....I can't wait any longer!
      Wellis77, I live practically in the middle of nowhere in the Mojave Desert...people like that are hard to find local.
      Jun 2010
      Deployed
      Wow! I almost forgot I posted this....Well "Cool Flex" doesn't seem to have product to sell and ship...This long and I still haven't seen it!
      Any opinions on these? http://www.summitracing.com/parts/su...placementparts
      Jan 2012
      Paso Robles, CA
      Speedway sells a radiator hose kit in aluminum which is just a sleeve and you can connect parts of factory molded hoses together just go to the parts house and look thru there supply and see what you can cut up and make work. They even sell one piece with a 1/4 pipe bung welded in so you can run tour steam hose into it.
      Sep 2007
      Southern California
      Quote Originally Posted by Roadbuster View Post
      For the ends you can get any radiator hose from the local auto parts and cut what you need. Take a wire with the bends you need and look at a bunch until you find one that has the bend you need and then cut that out.
      For my GTO I needed a larger lower hose to fit the radiator and water pump so I took the old hose and bought one for a truck that was almost the same just about 8 inches too long. Cut with a knife and done!
      Jon U.
      Build Thread
      a hose for a 4.8, 5.3. or 6.0 powered Silverado won't work?
      Apr 2004
      OKC, OK
      Is the battery still upfront to prevent the intake from going the other way? A dual pass radiator would also solve the problem but that is a bunch of $$$. If at all possible you need to route the hose lower thatn top of the radiator or it will be very hard to get any trapped air out of the system
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Jul 2010
      North Texas
      Bend a stiff piece of wire or clothes hanger to the shape you need, then go down to the parts store and see if you can match something up to what they have in stock.
      Dean P.
      '72 Buick Sun Coupe GSX
      My build thread: https://www.pro-touring.com/showthre...ck)&highlight=
      Dec 2010
      Fredericksburg, VA.
      Here's what I fashoned for a radiator hose. Two 90deg polished aluminum tubes and short silicon hose connections.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jun 2010
      Georgia
      were there flares on the ends of those tubes? If not, you really should consider putting some in (any muffler shop can do it for a few bucks). Makes a huge difference if and when you build a lot of pressure.
      Sep 2002
      So. Cal
      Do you own a welder or know someone who does?
      I purchased steel mandril bent tubing from summit and cut and welded what I needed. Sent out to Jet Hot and installed with Silicone ends...looks great.
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by SparkyRnD View Post
      Been there, done that!
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Feb 2008
      Denver NC
      Have you given any thought to cutting the extra threads off of the clamps? especially on an engine compartment that looks as good as that one That eats the ass out of me to see stuff like that... long bolts.... long hose clamps.... zip ties cut wrong....
      Need A T-101,Jerico or other 4 speed transmission serviced? Pm me....
      Dec 2010
      Fredericksburg, VA.
      I have been considering replacing those clamps with heat shrink clamps. I just haven't gotten around to doing it yet.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      savannah,ga
      how about the hoses for an 06 cadillac dts with a northstar engine?
      Jun 2010
      Deployed
      Quote Originally Posted by Tom Welch View Post
      Is it shaped like this? I want to rid of this SS Steel hose!
