Results 1 to 7 of 7
Do I need to reinforce the frame? 67' A body, SC&C stage 2 chassis
Hey guys. I just found out my stock cali frame is damaged beyond repair from a collision that happened 20+ years ago before i got the car and it wasn't correctly fixed. In fact it was completely butchered and ruined essentially. The car wont turn full left, sit level, bent rear arm etc.
Anyhow ill be changing frames on this car. I have a 67' GTO Montana, rust free frame ill be swapping out under it in the spring. This winter I was going to do a little work to it before I powder coat it. I intend to run an SC&C stage 2 chassis with the SPC lowers and bilstein shocks and some UMI control arm braces. Ill be steering with a 12:1 Jeep box. This will be a street car that I take to auto x events for good fun and maybe a run or two own the 1/4 for a good time but nothign overly competitive. Its primarily a street car im going to beat on. My question is this. Im looking at a kit from ABC to box the frame or i might just fab up some plate steel and do it myself. Reguardless of how i go about it.... Is this a good idea or is it money wasted? Is there any downside to this?
Here is the kit.... http://abcperformance.net/frame%20boxing%20kit.html
-Nick
-1967 GTO I drive and race
-Build threads:
11-02-2012 #2Since you are replacing the frame anyway, this is a no brainer. Boxing the frame and adding well engineered stiffening components will make a big difference in how the car rides and drives especially in agressive driving. Making sure the fuel and brake lines and exhaust pipes routes aren't blocked is the only tricky part. With a decently designed kit, that shouldn't be a real problem.
ShaneG
Used to be known as PT Judge
11-02-2012 #3
- Jun 2009
- From Wasilla, AK. Now portland, OR
- 172
