      Sep 2012
      What booster should I buy?
      1st gen camaro brake booster interference issue
      Big block in a 1st gen
      Roller rockers
      Tall valve covers
      Drivers side will not go on.
      Has stock 11" brake booster. I figure this will have to go, in favor of a smaller booster.
      Now, I am swapping brakes this winter, c5 corvette fronts and a generic rear disc swap.
      What booster should I buy? Anything I could grab from local parts store that I could make work with a little jiving?
      or from jegs that will bolt right up?
      Figured I ask here first before the camaro specific sites with little traffic in the 1st gen areas
      If possible, if like to buy the booster and master all together
      thanks!
      Apr 2004
      OKC, OK
      9" dual. If that won't clear I would go hydroboost.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Sep 2012
      Npd has a 7" and 9" booster for $250ish
      Is 7" too small?
      Also what size master?
      1"?
      1.25"?
      Oct 2010
      Sacramento, CA
      Right stuff dual 8" booster. I'm running one with an ls1 and my friend if running one with a 383 and tall edelbrock valve covers that hit his 11" booster.
      How is your wiper? His hit the valve covers too.
      Rick - 1969 Camaro - LS1 driven daily
      Sep 2012
      I had a SBC with tall alum covers. Cleared just fine
      Appleton WI
      I had the same problem when I swapped to tall Dart valve covers after re-doing the top end on my 502 and ended up going with a 7" Jeg's booster to go with a Master Power front disc kit that I installed in my '68 Camaro back in '01. I believe that it has a 1.25" bore but I'm not positive. A buddy of mine has a non-power Wilwood kit in his '67 Chevelle drag car that works every bit as well as my setup and I want to take that route late in 2013. Maybe check that out, especially if you have ever thought about going to a solid roller setup. :P
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Sep 2012
      Mine is a big block, looks to be plenty of clearance to the wipers
