    Results 1 to 17 of 17
      Texas
      Quote Originally Posted by garys 68 View Post
      I'm going to make your day.
      95 Impala/Caprice tank fits the 68-72 A bodies, it's sumped and baffled. The fuel sender works on your existing gauge. All that's needed is the upgraded fuel pump and 02 corvette filter regulator. I've run it on under 2 gallons of gas. Used tank/sender $80
      (came with 5 gallons of gas I used in my lawn mower), Racetronix pump (includes improved wire harness) $125, corvette regulator $35.
      Do not go external on the A body tank. It's low and wide and will have starvation problems on less than 1/2 tank. Some efi aftermarket tanks have the same problem.
      Tank
      Pump
      Installed
      God bless you, sir! Would you mind PMing me a contact number in case I have more specific questions down the road?
      This will really help persuade me in the LSx direction. Besides the motor/tranny, this was going to be a pretty hefty expense.
      Thanks again!
