Results 1 to 12 of 12
Thread: Alternator output voltage is low
10-02-2012 #1
I am finishing up installing a LS2/4l70e out of 2008 TBSS with a new 2005
Corvette accessory drive into a 69 Camaro. When the motor is running the alternator output is only 11.6v.
- Exciter wire - I soldered in a 470 ohm resistor inline on the red exciter wire in my harness going to the alt plug.
- Grounds - I have two 2/0 cables going from the engine to the body, the engine harness is grounded directly to the body and the trunk mounted battery has a 2/0 cable grounded to the body.
- All electrical connections & wiring to the alternator, battery and grounds are secure and free of any corrosion.
Even though the alternator is new I may have it bench check , but first does anyone have any suggestions?
