    Results 1 to 3 of 3
      Jun 2005
      Bruxelles Belgium
      How to connect vacuum lines?
      Hello,
      I'm in the process to connect the pressure lines to my Procharger system but I have some questions....
      I have the Procharger instruction book but I didn't find the infos inside....
      I have an Autometer boost/vacuum gauge, where must I connect it, to the intake under the carb ? Is it right to vacuum carb ports ??
      I also have an Aeromotive fuel regulator with an inlet for vacuum, a MSD boost timing master with also an inlet for vacuum and a Procharger blow off valve with also an inlet...
      I join a picture of 2 check valves, but I don't know where to place them?
      If you can explain me what go where and where to connect the check valves I would be very happy ;-)
      • The white one --) goes to the brake booster (but there already is a valve on the booster inlet, right ? ).
      • The small one --) to the TH-350 line ??
      • Blow off valve --) intake......???
      • Fuel regulator --) intake or carb hat ?
      • Boost Timing Master --) intake ?
      • Boost/vacuum gauge --) intake ?
      Must I keep the PCV valve or can I block the port ?
      Thanks for your help
      DavidName:  check valve.jpg
      1972 Buick Skylark Coupe Pro-Touring (of course!)
      1968 Pontiac Catalina Station Wagon
      1971 El Camino SOLD
      1978 Dodge B200 Tradesman Maxivan ShaggyVan
      UK London
      Hi Pro Buick,
      I'm going to have my afternoon nap. So here's the quick anser.
      The white one --) goes to the brake booster. It should be higher pressure rated than the stock one.
      The small one --) to the TH-350 line? Correct.
      Blow off valve --) intake below the carb/throttle blades.
      Fuel regulator --) carb hat. You can get a 1 /16th ntp nipple for it if you want to run braided hose.
      Boost Timing Master --) intake. Correct, again below the throttle blades.
      Boost/vacuum gauge --) intake. Correct. You can buy a manifold log on Ebay to connect all the intake feeds together. That is apart from the BOV
      which will work properly on it's own feed. Many use a 1" carb spacer drilled and tapped to accept 1/8th ntp - 4AN or quick connect fittings.
      Must I keep the PCV valve? No. It'll work better with either a really secure breather. (They can blow off due to boost getting past the rings). Or a pair of -12 AN tubes from each valve cover to a vented oil catch can.
      Good luck and have a read of this Procharging 101 post while your at it.
      http://www.yellowbullet.com/forum/sh...d.php?t=398738
      Jun 2005
      Bruxelles Belgium
      Thx
      Thank you for your advices....
      Heree is the result....but needs some jet tuning to run properly
      http://www.youtube.com/watch?v=n6_iO8tP504
      1971 El Camino SOLD
