Results 1 to 20 of 24
Thread: Squeezing out MPG's
Squeezing out MPG's
So, I am trying to improve milage in the Air Force 69 truck. Yeah, Starting with a brick is not the best for milage, but gotta have some coolness to right? Here are the details.
1969 C10 1/2ton
curb wieght 3300lbs
Truck is lowered 4" front 5" rear
Engine
355
Flat top speed rpos for about 8.9:1 copression
New GM basic 76cc heads
Comp Xtreme Energy Cam
212 int./218 exh. Advertised Intake Duration 256 Advertised Exhaust Duration 268 Advertised Duration 256 int./268 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.447 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.454 in. Valve Lift with Factory Rocker Arm Ratio 0.447 int./0.454 exh. LSA
Rams horn manifolds
2 1/4" mandrel exhaust with h pipe and 2.5" 2 chamber Thrush Mufflers
Edelbrock Performer Intake Factory Quadrajet
HEI ignition
M-20 wide ratio Muncie 4 speed
30lb Hays flywheel
3.73 Rear Gears
28" tall tire.
Running an electric fan, on a thermostat, engine maintains 190-200F
no powersteering.
Engine uses 10w30 Brad Penn oil.
Trans has Redline synthetic
Rear has redline synthetic
Right now I am averageing about 14 mpg.
My commute is 30miles one way, most of the time cruising at 60 mph.
At 60mph I am turning about 2600 rpms.
I was thinking about swapping to a 3.07 gear, this will drop my cruise RPM about 500 rpms. Will that make much difference?
The carb was built to match the engine. It is a bit rich now, and I am going to start tuning it a little better, but am still reading up on Q Jets.
I am running R45TS Plugs at .035". Planning on swapping in new ones and opening them up to about .045"
I am going to invest in a wideband o2 sensor and gauge to help with tuning.
Open to ideas, suggestions?
I have a tpi set up, but figure it would still cost about a grand to swap it.110
1971 Camaro 427 in waiting
1988 C1500 Daily Driver
