      Oct 2007
      Newark DE
      C6 upper ball joint taper? silver69camaro?
      I need to know the upper ball joint taper for a C5/ C6 spindle. Tried to measure the taper from the stock C6 UCA but I came up with 7.35 (or something) degrees. Figure this is do to the chamfer on the big end of the hole but not sure because a web search says 7deg or 1.5" per foot, 10deg or 2" per foot, or 7.5- 8.5 deg. Not sure who to trust besides the people here.
      Thanks for any help
      Mar 2004
      Mid-Michigan
      Hey Eric,
      They are 7deg.
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Oct 2007
      Newark DE
      Thank you Mark!
      Feb 2010
      ARIZONA
      The most common taper is 1 1/2” per foot (1:8), which is 7.181 degrees which is rounded off to 7 degrees. The second most common is 2” per foot (1:6), 9.594 degrees which is rounded to 10 degrees. This is what I get for the 2010 Z06 upper and lower ball joints and the tie rod ends . Others are 1” per foot (1:12), 4.780 degrees and rarely 1 in 10, 5.739 degrees.
      Last edited by MIKE67; 10-07-2012 at 04:37 PM. Reason: Corrected which taper is on the C6 David Pozzi pointed out that the taper angle is the included angle, not one side.
      Larry
      67 Camaro, 350 SB, Custom A-Arms & 3-Link
      My Build https://www.pro-touring.com/showthre...LOVE-67-Camaro
