    Results 1 to 20 of 40
      Midwest
      1969 Mustang BOSS 302.0: DSE Suspension, 5.0, V8TV Build
      HI-RES LINK: http://v8tvshow.com/BOSS302.0/hi-res/V8TV_BOSS302L.jpg
      We are have started another cool project in the V8 Speed & Resto Shop (AKA V8TV) - The BOSS 302.0!
      This 1969 Mustang was literally a barn find and will be going through a complete transformation in our shop with some high-tech parts designed to make this a comfortable street cruiser that will also perform on an autocross or road course.
      The body shell will remain stock appearing, except for the addition of some carbon fiber body pieces from Anvil Auto. The Steinhauser Design rendering illustrates the clean appearance with the Anvil carbon fiber hood, bumpers, rear deck, quarter extensions, and dash face. Also visible are the Forgeline wheels and big brakes.
      Under the hood is a 5.0 Coyote engine and a manual transmission. The suspension is all from Detroit Speed, utilizing their new Mustang AlumaFrame and Mustang Quadra Link in the rear.
      We will be posting pictures and videos of the build of this car in this thread, and as always, feedback is appreciated!
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      SoCal
      Great looking project, will be keeping a close eye on your progress. Excellent digital documentation so far!
      Lake Ontario, NY
      Quote Originally Posted by oestek View Post
      Sounds like another very interesting project for you guys Kevin.
      Great rendering obviously as well.
      Skip
      Oct 2011
      Katy, Tx
      That is awesome... New Detroit Speed parts... Love the way all that is looking!
      SF Bay Area
      No updates yet?
      Ha! Anyway, should be another cool project for you guys. Can't wait to see how it turns out.
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
      Midwest
      Wow, glad to see the positive feedback! Thanks!
      We're very stoked about this one as well.
      Here's what we're starting with:
      It's a pretty clean AZ car.
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      May 2012
      St. Louis
      Very, Very Cool.
      I'm biased of course, but the rendering is drop dead gorgeous.
      So what do you suppose this bad boy and the 69 Camaro you are also building right now will talk about when you leave them alone together at night?
      Midwest
      Right now, I'm pretty sure both cars would be screaming in pain right now if they could talk!
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      Midwest
      Here is proof that this car came out of a barn!
      During the disassembly process, it appeared that we had a fairly clean car to start with.
      The floor had some surface rust and the footwells appeared to be soft.
      Some grinding here and there revealed ugliness in the doors.
      And the driver side quarter panel was a victim to some previous repairs.
      We trimmed the majority of the damage quarter panel skin, leaving the original edges and creases in place so that we could accomplish two things. First of all, this will allow the
      media blaster better access to the inner structure of the car. Second, it retains the alignment points for when we go to install the new quarter panel. When that time comes, we will install the deck lid, quarter extensions, and door before trimming the remaining edges of the original quarter panel. This will allow us to align the new panel to those pieces properly.
      We took a few minutes to make a closeout panel for the old heater box because we will be installing a Vintage Air AC system.
      Next up, the media blaster!
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      Midwest
      The BOSS 302.0 survived its visit to the media blaster with minimal surprises.
      The blaster left a few pieces of duct tape on the car to use as guides to illustrate how much filler was on the car in various places. The tail pan was toast, and the passenger quarter was pretty wrinkly from crash damage.
      It's kind of hard to tell in this pic, but the passenger quarter was pushed in about 1/2" and had been pulled before.
      Other than the quarter panel damage, the blasting process did not reveal any new surprises.
      After the initial inspection, the crew spun the car on the Autwirler while blowing it out to free any loose blasting media. THen they attacked the car with an 80-grit DA sander to knock off the rough media blast texture, then scrubbed it with Scotchbrite pads and wax & grease remover before a final blow-down and BASF EP760 Epoxy Primer.
      You'll note that the panels targeted for removal were not primed completely to save on materails.
      Overall, the shell is very clean, and will provide a great foundation from which the BOSS 302.0 will evolve!
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      Midwest
      The BOSS 302.0 will be running the Ford Racing 5.0 Coyote engine, and the package comes with a controller and harness to make it all function.
      The harness resembles most EFI harnesses, with a couple extra connectors for the 4 cam position sensors. The Coyote makes 412 HP and weighs 440 lbs, and all 4 cams are variable. Pretty cool stuff.
      The ECM is a OE grade unit, and is OK to mount under the hood or even in a fenderwell. The manual explains the options.
      We like the supplied power center, which houses the relays and provides LED indcators for quick visual verification of succesfull operation of each circut. We like to put these in the glove box so you can see what's up at a glance.
      These engines do not have provisions for power steering pumps, as the new Ford cars they power have electric steering.
      Here you can see the Vintage Air Frontrunner serpantine belt and A/C system for the 5.0. The Vintage Air unit adds the pump as well as the A/C compressor in a tight package.
      The 5.0 is an aluminum engine, and although we love the look of the raw cast block, heads, and bracketry, we hate how the aluminum oxidizes and turns ugly over time. So we've been coating engines with Eastwood's Ceramic Engine Paint in Aluminum Silver. We shot a test part with this stuff and cooked it to 500 degrees in our oven without any hint of color change or blistering, and it resists solvents. So now aluminum parts stay looking like aluminum thanks to the "nano ceramic technology". That's OK, I don't know what it means either.
      Here's a sneeky-peeky of how the 5.0 fits in the engine bay with the Detroit Speed Aluma-Frame underneath.
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      Feb 2008
      DSE installation video up soon? what transmission are you running behind the Coyote? lots of cutting to get the transmission in?
      Midwest
      The suspension video and pics will be up next week. We are going to run a TKO 600 in the car, but we have not installed it yet, so I cannot speak to the trans tunnel cutting. We're still waiting on the engine mounts to arrive from DSE to place everything. Stay tuned!
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      May 2011
      Country Flag: France
      Just curious, Boss 302 without the Ford Boss 302 intake? Is it a packaging matter, after getting the chance to try a regular 5.0 and the Boss version, I got to say that the Ford racing Boss Intake is worth a scoop!
      Nice project
      1972 Nova " Hotwhilz Special"
      https://www.pro-touring.com/showthre...t&goto=newpost Under the knife!
      Sydney, Australia
      Country Flag: Australia
      School me a little with the power steering.....is it not an option to run the electric powersteering pump system that the Coyotes normally use...or it it just cost effective to go with an Engine Driven Pump power steer system?
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      Apr 2011
      North NJ/SW Virginia
      If I'm not mistaken there is no power steering pump at all, the steering rack is moved by an electric motor not hydraulic fluid.
      John McLoughlin
      1970 Pontiac Lemans
      https://www.pro-touring.com/showthre...-Lemans-Update
      Sydney, Australia
      Ahhhh....OK, thought they were jsut using an electric pump. Explains the need for an EDP.
      Regards,
      Leigh
      Sydney, Australia
      1971 Firebird 455
      Midwest
      Correct, they use an electric motor on the steering column and a manual rack. Flaming River is making such an animal, which seems to be based on the Ford system, but we are using the DSE rack. We also require the pump for the Hydratech hydraulic assist brake booster.
      Flaming River unit:
      Kevin Oeste
      V8TV
      V8 Radio Podcast
      All about us:
      BC Canada
      You couldn't have started this project at a better time. My father has a '70 boss 302 and he has been asking me what kind of suspension mods are out there that people are doing. He wants to keep it mostly original except for the suspension. I'll def be pointing him in this direction.
      Very much looking forward to seeing future updates,
      Jan 2009
      Chattanooga, TN
      Never seen anyone mask with aluminum foil. Not a bad idea!
      The motor looks sweet!! Keep up the good work!
      Stephen S.
      1967 Ford Mustang 4.7L, T5
