      Niceville, Florida 32578
      Accu-Link on a Roots blower
      If anyone has mounted an Accu-Link on a roots blower with side mounted Holley's, I'd love to see some photos of the installation. Thanks.
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
      Finally got everything to work together. I really wanted it below the hood line but I just could not get the proper ratio. Looks like I'll be putting the weather tight connectors to the test.
      Edmund Burke
      Finally got it to work below the hood. A bit Rube Goldberg-ish but functional and the wiring is hidden.
      http://www.youtube.com/watch?v=VCQj6...ature=youtu.be
      Edmund Burke
      Jan 2003
      Arizona
      Is there any way to use one of the holes that is further from the hinge point? If not, then I suggest softening up the tables in the 50-70% range. As is, you have a rather steep motion ratio. The software CAN compensate, but I like to see a more gradual motion-- especially with that big honkin' blower. Sounds great!
      ________________
      Steve Chryssos
      I tried the outer holes but the TPS was "bottoming out" and preventing me from getting more than about half throttle. I had to drill and tap a hole much closer to the axis just to match the limited arc of the TPS. The throttle is pretty stout with 6 springs holding it back. Seven if you count the TPS.
      http://www.youtube.com/watch?v=Cn067...ature=youtu.be
Size:  108.0 KBName:  16022373_large.jpg
      Edmund Burke
