    Results 1 to 10 of 10
      Muncie will it work?
      Hello everyone .. a couple of questions first a little backround 69 firebird with 400/4sp muncie converting to a ls3. I have a line on a 22thousand mile ls3 running in a 08 vette. He wants 5k does this sound fair? also I would like to use my rebuilt muncie four speed and drive shaft to cut down on cost is this possible? thanks in advance Phil
      May 2002
      Northern California
      5K is a great price for a running LS3.
      You could use the Munc with the right bellhousing, clutch and release bearing. You can use a z bar but that will depend on the headers that you will use.
      We ran a Quick time Bellhousing pn RM-6036, Mc Leod 1308 hydraulic release bearing, 2001 Camaro T56 pilot bearing (small) and GM LS3 Clutch. You will need a 10 spline clutch disc.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2010
      St Louis
      Motor sounds reasonable if you get accessories, harness, ecu, pedal, etc.
      As for the Muncie
      http://ls1tech.com/forums/conversion...-ls-motor.html
      Sep 2008
      How many people run muncies with ls1s?
      Nor Cal
      Quote Originally Posted by Oakesters View Post
      maybe 1 in 500?
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Dec 2010
      St Louis
      Um yeah, that would be me. But mine was a cost factor and worked well with my combo.
      Heavy 72 Olds, 2.73 rear, relatively small 5.3, so a T10 4 speed with 3.42 1st works out pretty well as a daily driver.
      There are a few weight concious swaps using them too.
      Quote Originally Posted by Flash68 View Post
      maybe 1 in 500?
      Jun 2010
      Deployed
      I know easier said than done...but I would sell that 4 speed and pick up a Magnum or a TKO. The modern engine is just that much more better with an OD trans. Which muncie is it? May have good re-sell value.
      1970 Camaro/DSE build
      Sep 2008
      Just thinking of a cheaper way to get a ls swap done , didnt the 48 hour camaro has a muncie?
      Jun 2009
      Piqua, Oh
      Just thinking of a cheaper way to get a ls sway done , didnt the 48 hour camaro has a muncie?
      That's what it started out with + a Gear vendors OD. It has T56 Magnum in it now. (unless they changed it again, since last time I talked to Bret)
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      Dec 2010
      St Louis
      Another advantage in the 68-72 A bodies, no cutting the tunnel. T56s are too big.
