    Results 1 to 20 of 22
      Aug 2008
      jacksonville,fl
      I did an ls1 install in 03' into my 83 el camino using the factory compressor, which failed twice. Later switched to sanden using BRP brackets, worked fine with the factory system. Later switched to vintage air to clean up under the hood & to change out other failing factory components. Local air shop capable of making hoses did my airlines & hookup each time, I did other fabrication. notched my crossmember behind compressor & cut & reboxed frame behind steering Idler for factory compressor. Sanden(508?) in pics takes up less room.
