    Results 1 to 10 of 10
    Thread: come on dse!
      corona,ca.
      come on dse!
      Attachment 62483Attachment 62484 they said these brackets are one off and no plans for production parts :-(
      corona,ca.
      Sorry i forgot to add this is on a 70 chevelle.this is what i need it looks so damm trick!
      May 2010
      New Zealand
      Country Flag: New Zealand
      Haha you're really not keen on the GW bracket are ya..f.air enough I guess. Gotta say that thing ^ looks solid!
      Is it intended to run a reeealy long stock style spring or a coilover?
      Chris
      68 El Camino - Street Track Drag - in progress..
      Toyota Station Wagon - only thing that actually runs....
      Indianapolis, Indiana
      How good of a fabricator are you? The reason I ask is you can get the coil over bucket from TRZ suspension for their front coilover kit and then drill the hole out bigger and install tabs for the coil-over. Check out their site.
      Ben Mowery
      67 Firebird -Powered by Pontiac w/ RAM AIR V.
      corona,ca.
      Quote Originally Posted by 67bird View Post
      Thanks ill look into trz,and yes im pretty good. With fabrication im a machinist by trade not cnc thou
      Santa Clara, CA
      I thought a Chevelle was a full-frame car?? What do I know... :-(
      Steve
      Los Angeles, CA
      Quote Originally Posted by sjaroslo View Post
      Chevelles are full frame cars like all GM a-bodies, but DSE cut the frame up firewall forward. I do not know why, but whatever those guys cut apart, I can assure they can weld is back together!
      Don
      Apr 2004
      OKC, OK
      you could always graft in an X-gen clip which will have similar geometry.
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      corona,ca.
      I called them they said the cut the frame off because it was easy for them to work on thats all.for 140 bucks i think instead of the trz buckets i could just get tube from work and make the plate up top on the lathe...lets see!
      corona,ca.
