    Results 1 to 20 of 29
      Nov 2004
      Eastern Washington
      Opinions on my combination thoughts.
      Hello.
      I want a nice powerplant that gets pretty good gas milage and has excellent driveability. What do you think of this combination?
      http://www.jegs.com/cgi-bin/ncommerc...28&prmenbr=361
      http://www.jegs.com/cgi-bin/ncommerc...16&prmenbr=361
      and a TK500 transmission (or T-56...havent figured out exactly how much would have to be done for the t56 to fit in a 79 TA).
      But as far as the engine combination goes, what do you think I will see in regards to gas milage and HP gain/loss due to the EFI? Plus I can sell the carb and manifold to pay for part of the EFI
      Nov 2004
      Eastern Washington
      ...Oh yeah. One main requirement...I have to be able to keep my shaker hood. That is why I didnt suggest the Ram jet
      Sep 2002
      San Jose, CA
      The 330HP engine is a nice combo, but that Edelbrock fuel injection setup is a piece of junk. The hard parts are not bad, but the ECM and the ability to be programmed is awful.
      If you want Fuel injection I would suggest staying with either FAST or Accel DFI. Yes they do cost more, and there is a good reason... they work better.
      Poor running EFI can be one of the most frustrating things there is, spend the extra money up front to do it right.
      another note, the 330HP engine uses L31 Vortec heads, which have a special bolt pattern on the intake. You cannot use a conventional intake on those heads, it must be the Vortec style.
      Just call me Brett
      Nov 2004
      Eastern Washington
      Thanks for the advise! I am new to efi and basically the Edelbrock was the first one I could find that would let me keep my shaker hood. I really like the GM Ram Jet, but would lose the ability to keep the shaker.
      Who makes the FAST and Accel DFI that you mentioned? I have seen traces of them, but dont know anything about them.
      Beaufort, SC
      330hp would be killed to less than 285 at the tires (given the driveline robs only 15%). Might want to look into at least 400 at the crank in the late 2nd gens if you want to get down the straightaways quickly. IMO, 285rwhp is nothing in a 3500lb car (less driver). I had over 400rwhp in my camaro (3420 less driver) and it was plenty for me. I would say that anywhere from 340-380rwhp would be perfect for a true driver that can be driven at all times.
      '72 Chevelle- 4 wheel 12" Discs, Konis, Hotchkis springs (shortened an extra coil up front), 17" Cragar Soft 8's with 245's in front and 275's in back. ---STILL IN PROGRESS---
      Sep 2002
      San Jose, CA
      Just call me Brett
      Nov 2004
      Eastern Washington
      Quote Originally Posted by deadcarny
      Hmmmmm.....so I may be back to the 502 again.
      Jackson, Michigan
      If your looking for a good deal get a old style fast. For what your doing bank to bank would be fine and with Fast's new xfi coming out some dealers are blowing out the old style ecu's. Also theres another company called bigstuff3 that has a real nice ecu. To give you a idea what they cost i will list some general pricing.
      BigStuff gen3 with wideband o2 1795.00 or with data logging internal 1995.00
      Fast xfi with wideband o2 2150.00
      Accel gen7 no wide band 1500 plus ad the cost of a wide band.generally between 200.00 to 1000.00.. get what ya pay for here.
      Not sure what what the old fast is going for . It depends on how bad a dealer wants to get rid of them . Would be less for sure than the xfi. The above prices are list also so if you can find it cheaper then thats good.
      Then you will need a host of other stuff. The wiring harness is included in the stuff listed but there are a bunch more stuff you need to finish a complete efi setup. some of those are.
      Injectors 400 to 500 for a good bosch or delphi .
      Throttlebody 400.00 to 550.00
      fuel pressure regulator 150.00
      Sensors = tps, iac, coolant temp, air temp. map ...figure 200.00 to 300.00
      fuel pump ? depends on what ya want
      Fuel cell? also depends . there are several options.
      Misc fittings ?
      Fuel lines, return and feed?
      o2 bung for your headers. 15.00
      If you want timing control you will need a regular pro billet for sbc plus a msd crank trigger and a msd 6al. or a msd 2345 cam sync distributor and a 6al.. all this assumes sequential.. Accel has there own plug and play distributor but I have not looked into what it would require so i am no help there. Or I guess you could buy a complete system from Accell. It has everthing minus the distributor and wideband o2.
      Also Holley has a system called commander 950. It can be bought in a 2 part kit. One price for the computer and harness and then stuff like the manifold, sensors, injectors and so on. They might even have it all in one box not sure. It would do all you need. I have not researched prices yet so im no help there. Should be cheaper than the seperate route listed above
      This is the result of about 2 weeks of reading and knowing me it's all worthless .lol. Do with it as you will.
      Peace
      Steve
      Beaufort, SC
      Quote Originally Posted by Kuhlryde
      Too heavy, unless you are going to move the engine back a little to fix the bias.
      Nov 2004
      Eastern Washington
      OMG I am new to the EFI way of doing things and all of this information you guys are supplying is a whole LOT to take in. Maybe I should start from the beginning.
      I would prefer my first engine replacement (I have done VW engines in the past...no comparison for easiness here) to be something fairly simplistic. I like the idea of a GM crate, while modifying it for EFI myself....but I am open to suggestions. I have plenty of time to figure this out.
      I really like the idea of the 400+- HP engine. I guess I assumed it would be too much.
      If I go with something like that, what should I be looking for with the specs for an ideal EFI setup? Do you think something like this would be better suited or is the compression too high?
      http://www.jegs.com/cgi-bin/ncommerc...83&prmenbr=361
      Maybe a GM crate engine is out of the picture at this point?
      Jackson, Michigan
      compression looks good to me.. To decide what would be the best efi setup I would wanna know more what you wanna do with the car.. Oh forgive my ignorance what kinda car is it? What Hood you gonna run or have. Is it gonna have ac? How about nitrous?. Sorry for the above post I had to get that off my chest .lol
      steve
      Oh to answer you question. With efi hp prolly close to the same with a little better mileage.
      Nov 2004
      Eastern Washington
      Quote Originally Posted by SSMOORE
      Actually that was a HUGE help to me. I like knowing what all I need before I start researching how it works together.
      The car is a 1979 Trans Am. I will be making it my daily driver, so A/C will be used. My biggest personal requirement is that I can still keep the shaker hood. I have not yet decided on nitrous. I probably wont use it, but the possibility is always there. I will also be incorporating (at least) at Tk500. I might put in a T56 (which is preferred), but that would require a lot more work.
      Jul 2002
      Muskegon, MI
      You are on the right track. Get one of the small block engines but get more than 330HP like what was mentioned above. Dont get the 502 since your looking for decent gas mileage and it will be your daily driver.
      Conclusion. If you want a crate engine that is fine. Just get one with more Hp than 330 and you wont regret it.
      I am personaly very happy with what I have. Its a 383stroker with a little over 400hp and can still pull off 20mpg on the highway with a carburetor. So fuel injected would be even better mpg. Good luck and keep us updated.
      Nov 2004
      Eastern Washington
      Oh wow. 20mpg? For some reason I thought you had an ls1. Where did you get your 383 from?
      Jul 2002
      Muskegon, MI
      I had a local shop build it for me and I installed it. I kept the stock cast iron heads so with aluminum heads it will run even better. Keep in mind my 20mpg is only on the highway. I also have a T-56 6 speed that helps a LOT with my 4.11 gears!
      My average between city driving and highway is around 15mpg with a 750 carb and 4.11 gears. Not bad at all IMO.
      Nov 2004
      Eastern Washington
      Not bad at all...especially when you consider I have a Pontiac 400 (220 measily HP) with a 4 speed and I get 12 highway.
      Jul 2002
      Muskegon, MI
      Before I installed the T-56 I had a Borg Warner 4 speed (1.00 4th gear ratio) and I was lucky if I got 10mpg on the highway.
      I doubled my MPG just by installing the t-56 and now I can easily go 70mph instead of 55.
      Nov 2004
      Eastern Washington
      That is incredible. I want to put in a T56, but I dont know if I can do the work. Not as easy as a first gen would be (from what i understand).
      Has anyone delt with 'American Speed'? I hear they do good things:
      http://www.amerspeed.com/
      Nov 2004
      Colorado
      Scoggin Dickey is an Accel dealer, and has good prices. If you want to keep your shaker, look for a EFI system that is built on a single plan manifold, like a Victor Jr.
      Accel sells complete plug and play systems that work with the GM crate engines.
      Sep 2002
      San Jose, CA
      I was just gonna mention that... The ZZ4 is still a VERY nice engine combo for a daily driver and Accel sells an EFI system that is already setup for that specific engine.
      It will be kinda like driving around in a 87-92 Corvette, except without cracking paint ;)
      Keep in mind that you are going to need to buy brackets and such to convert from the Poncho motor to the Chevy.
      I am a fan of the Accel setup, very tuneable. If you ask me on a fairly low HP street motor having a wideband O2 really dosen't buy you anything. All of the mentioned systems are Speed Density based, which means they basically measure manifold pressure and relate those measurements to pre-determined tables of A/F and Spark advance. Not a bad system by any means, but unlike a MAF style setup they are only so sensitive to changes under partial throttle.
      I suggest you contact Paul at Dyno West in San Jose (408 298 3968) he is the man when it comes to fuel injection conversions and can steer you in the right direction.
      A few years back we did a F/I ZZ4 in a Porsche 911... jesus did that car go like hell
      Just call me Brett
