    Results 1 to 16 of 16
      May 2002
      Northern California
      Remove the lower trim first. Comes off with a series of screws.
      Use a trim tool to unhook the trim starting at the lower corner and work your way up.
      slowly drag the trim tool under the trim you will feel it catch.
      Gently pry the trim up with your finger as you rotate the tool under the trim.
      Pop one at a time till you remove the trim.
      Once all the trim is off you can use wire or a flat blade on the inside of the car. While holding the blade along the glass push down to cut sealer. If you have rust down there it will most likely be an easy job.
      Once most of the sealer is separated push from the inside and have a helper grab the glass from the out side.
      trim removal tool
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
