Results 1 to 12 of 12
Thread: Hydraboost backfeeding master
I have been running my hydraboost for a while with no issue. I recently went through a PS pump and replaced it. I was advised to install a cooler to keep the PS fluid temp down and preserve the new PS pump. After installing the cooler the brakes will immediately look up upon firing the car up!
It appears that the added line between the T connection on the return side from the steering box and hydraboost going to the cooler and back to the PS reservoir causes the pressure to back feed to the hydraboost. It looks like the pressure is taking the shortest route and backfeeding the hdraboost. The return lines are T'd together near the steering box.
I am thinking of using longer return lines from both the steering box and the hydraboost and making the T or Y connection much closer to the cooler. My cooler is mounted in front of the core support on the passenger side (only place available). The T is near the steering box, originally connected to the reservoir with approx. 6" line. The new cooler lines are approx 3 ft each; adding an extra 6ft of return line.
Does anyone think i will experience the same issue?Aaron R
07-25-2012 #2There must be quite a bit of restriction in that PS cooler you just installed to cause that much backpressure in the low pressure return circuits. Your replacement PS pump may also be flowing WAY too much, which will aggravate the scenario even further. That much resistance to flow in the cooler will actually build more heat in the PS system than it will be able to remove, doing more harm than good (due to high pressures in the low pressure return line circuits - ideally should be a MAX of 1-2 PSI). 5-6 PSI or more will cause the brakes to start self applying due to back pressure on the hydraulic brake assist unit's low pressure return port.
https://www.pro-touring.com/showthre...boost-on-track
https://www.pro-touring.com/showthre...ht=#post875181
http://www.lateral-g.net/forums/showthread.php4?t=36999
The links above hold the key to your success - read them through thoroughly.There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark
Founder / Master Engineer
Hydratech Braking Systems ®
www.hydratechbraking.com
07-26-2012 #3Thanks Paul for the information. As suggested I did some 'homework' last night, starting with reading your post and the references. After reading I ran out to the garage for some measuring and additional checking of my configuration. I found the T runs straight through from the steering box return straight through to the PS pump return. The HB return connects to the branched end. That makes sense since it worked fine before adding the cooler.
I then checked the output on the pressure side of the pump and the orifice measures 9/64. Based on your reading material, that should be approximately 2.4 GPM flow. I think you suggested that is within the acceptable range? If not let me know.
I measured my 6 AN hoses. I found my hose (which came premade with ends) to be nylon with an interior hose dimension of 0.30. I found the rubber 6AN hose to have a slightly larger interior dimension of 0.34.
I measured my 6AN fittings and found the premade fitting has an interior dimension of ¼, while the non-premade fitting had an interior dimension of 13/64.
I wasn’t able to measure the interior dimension of the cooler fitting, but it’s a 6AN cooler approximately 5x11 in overall dimension. Don’t recall how many passes.
Also, my AN fittings are 90 degree ends. If I have to change out the premade end I will go with a 120 degree end for better fit.
I like the idea of plumbing the HB return straight to the PS reservoir and will look into it. But that alone won’t resolve the restriction issue.
Do you think the 90 degree ends impact the flow? Do you think the interior hose dimension, especially the 0.30 one, is too restrictive? Do you think the 9/64 high pressure orifice flows too much? Any other suggestions?Aaron R
07-26-2012 #4It is not the ID of the lines or hose end angles causing the issues. If you want to prove this out, simply place the T fitting AFTER the cooler you have installed (as you currently have it installed before the cooler). If I had the choice or various different pump output fittings sitting on the bench (which I do), I would run the .125 orifice first, then road test and evaluate to verify that it provided enough flow for everything I asked of the braking and steering. If so, then I would leave it be. Do you still have your original pump? If it is of the same design, you may want to check it for orifice size and possibly swap it out with the one that is currently installed in your replacement pump (if the orifice is indeed smaller).
Excessive flow builds excessive heat...There IS a difference - Thank you for choosing Hydratech!
Paul M. Clark
07-26-2012 #5I do still have the original pump. I replaced the pump with the same OE pump. I actually took the measurement of the output fitting from the original pump, and assumed they would be the same.
I will try the T after the cooler and run the steering box retun to the cooler first, then from the cooler to a T, then back to the reservoir.
This would mean the HB return doesn't get cooled. I assume since there isn't much coming through that return (as I understand from the reference reading) that it shouldn't matter if its cooled or not. I'm good with that theory.
So if i understand you, you are suggesting the pump is running too much volume causing the backbressure? But it works fine without the cooler. Or you are suggesting the cooler is restrictive. Or a combination. I will try to also gage the flow/restrictivness of the cooler.
Thanks again for your input.Aaron R
07-26-2012 #6The replacement pumps we have seen over the years can have totally different orifice sizes - you may find it to be the same as the old pump. IF you find the replacement pump does have a larger orifice than the original, I suggest you swap out the pump output fitting to run the smaller orifice. The pump may be flowing more than needed AND / OR the cooler is too restrictive. It befuddles me how many coolers we have run across that do not flow freely despite their outward appearance.
Paul M. Clark
07-27-2012 #7
