      May 2012
      Thousand Oaks, CA
      SBC crank bolt stripped
      So it looks like the crank snout threads are stripped on my gen 1 sbc. Any ideas how bad this is? I had pulled the timing chain cover to check the chain alignment, which turned out to be fine. The engine is in the car, which is going to make things a bit more challenging.
      Shawn
      Aug 2006
      I feel your pain. I have done this also. I think the crank bolt is 3/8 20. You can fix this with a heli coil thread repair insert. Supposedly they are stronger then your original threads. You can try and fix the the stock size or go up to 7/16. What ever bolt you use make sure you can a harmonic balancer installer with those threads. When you are putting the balancer back on heat it up in the oven on 200 degrees for about 15 minutes. It will make installation easier and put less stress on your newly repaired threads.
      May 2012
      Thousand Oaks, CA
      Hmm, I will have to look into a HeliCoil. I think I actually stripped it ages ago when I put on the harmonic balancer using just the bolt.
      That will teach me.
      shawn
      May 2012
      Iowa
      I just did mine crank with heilcoils I have no problem with it.
      May 2012
      Thousand Oaks, CA
      Do you have the info on the coil you used?
      shawn
      May 2012
      Thousand Oaks, CA
      Quote Originally Posted by Gregersen46 View Post
      Also, was your crank in engine, in the car? Just wondering how difficult it will be to drill it out straight and install it in the car.
      Guess I will be pulling the radiator at least.
      shawn
      Aug 2006
      I did mine in the car without the radiator. It was a 68 camaro. What type of car is it?
      May 2012
      Thousand Oaks, CA
      Quote Originally Posted by FMG CAMARO View Post
      68 Camaro ;)
      shawn
