    Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 61 to 80 of 124
    1. #61
      Port Richey Fl
      Quote Originally Posted by 1fststang View Post
      Rusty,
      Is that roll bar from Mustangs to fear ? if so it looks like you welded it in as opposed to being able to unbolt it and remove it is that what you did?
      How was fitment and are you happy with it?
      We bought a Mustang to Fear roll bar but it did not fit right. The top center bend was not in the middle, the bar was twisted and the bends were not the same on both sides. We took a lot of measurements and the owner bought some new material and went to ART (Applied Racing Technology) in Clearwater Fl. with the original roll bar. They wanted to make it flat across the top but the owner wanted it like the Mustang to Fear bar but bent in the center. They put the dimensions in the computer and bent a new bar and it is almost perfect it's off a little at the bottom but the trim panel covers that.
      It bolts in the front brace is welded to the bar.
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
    2. #62
      Port Richey Fl
      I have had questions wanting to know what issue this would be in and I'm happy to say it's in the March issue that just went to the printers.
      This is what Brian has been fabricating. It is an under the dash hood release. The hood required a lot of fabrication along with this latch that came off of another Ford. To find out all the details you will have to read the build story in an upcoming issue of Modified Mustangs & Fords magazine.
      Rusty Gillis
    3. #63
      Port Richey Fl
      We wanted the rear to look stock so I sprayed it SPI red oxide epoxy
      Rusty Gillis
    4. #64
      Port Richey Fl
      The engine came in a couple of weeks ago
      We had to change the motor mounts to Ron Morris adjustable to clear the hood.
      It runs on pump gas and makes 502HP @5900 and 533 ftlbs torque @3600. Click to see the video.
      Rusty Gillis
    5. #65
      couple questions Rusty
      Engine looks sweet. Is that a concept one serpentine belt system?
      I see you used Ron Morris mounts. So this fits under factory hood?
      I am assuming that is a 351w based stroker. Mind telling me what intake he is using?
      I am installing a 351w stroker as well and hoping to fit under a factory hood and I am using the edelbrock rpm air gap and I have the r morris mounts with lower plates. According to my measurements I think it will just clear.
      Also on the roll bar plates how thick are they? I am installing one that has 1/4" thick plates and wishing I had a 220v mig instead on 110v.
      Quote Originally Posted by rusty428cj View Post
    6. #66
      Port Richey Fl
      We are waiting for a dropped air cleaner base to give us a little more clearance.
      The block, heads and intake came from Dart
      Yes it is Concept One and the owner wanted it black.
      Roll bar mount kit came from Mustangs to Fear and I don't know how thick it is.
      Rusty Gillis
    7. #67
      Jan 2010
      SLC. UT
      Great work! I like all the progress pictures.
      Jeff -- 96 Mustang - 2V Stroked Modular Turbo // 13 RAPTOR // 67 Mustang Fastback build - Coyote 5.0
    8. #68
      Port Richey Fl
      The owner wanted the car assembled so the stainless exhaust could be designed to fit around the Total Control Products rear suspension and subframe connectors in case anything had to be modified before paint.
      On the way to the exhaust shop on a dreary rainy day here in Florida
      Rusty Gillis
    9. #69
      SF Bay Area
      You get a vin from Dynacorn.
      But, I'm guessing, that these VIN's issued by Dynacorn are nothing like the original Ford VIN's, right? So, subsequent buyers will be able to immediately tell this is a aftermarket car. Meaning, I guess you could add whatever options you wanted and call it 'original'
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    10. #70
      left coast
      Really liking the forum over my usual reading, especially with all the hands on work, helps to eliminate allot of questions. Back on page three you did something to the roof/quarter seam and A pillar that really caught my attention. Rather than soldier or fill, you welded in a plate between the roof line and quarter panel. Looked awesome, great idea. Realizing these joints flex in a typical unibody, but I also have subframe connectors and front torque boxes in my 66 coupe. Will that joint hold up? If it does, I plan on doing the same. I replaced a full quarter and have been questioning what to do to fill the seam.
    11. #71
      left coast
      Whats the possibility of getting the measuments and bends on the rollbar? fax ya a beer.. . .
    12. #72
      Jan 2012
      Port Richey Fl
      Sorry I have forgotten to update.
      Stainless exhaust
      Rusty Gillis
    14. #74
      Port Richey Fl
      Brian cut the holes for the speaker and light in the door and lined up the trim
      We removed the engine and transmission
      Rusty Gillis
    15. #75
      Jun 2015
      San Diego
      thats one hot stang
    16. #76
      May 2013
      nj
      Great thread..alot of work for a new body.enjoying the build. Thanks
    17. #77
      Port Richey Fl
      A few new problems. Brian is test fitting the windshield molding and of course they don't fit.
      The next problem is the brackets for the fold down rear seat are welded in the wrong location on the wheelhouse
      This is how it should be mounted
      It is mounted to high
      This is the opposite side
      Rusty Gillis
    18. #78
      Apex, NC
      Starting to come together
    19. #79
      May 2010
      British Columbia
      I noticed that you've used sheet metal screws to retain the windshield trim . I'll have to as well , do you re-call what size screws they are ?. Nice build by the way .
    20. #80
      Port Richey Fl
      Quote Originally Posted by langleylad View Post
      The reason we had to go with the screw in studs was because they broke when you attached a clip and they were in the wrong place
      http://www.ebay.com/itm/CRL-4-X-3-8-...item2a41740835
      Rusty Gillis
