    Results 1 to 11 of 11
      St George Utah
      Speedtech Performance 70-81 Camaro/Firebird Torque Arm Rear Suspension
      Here are some new pictures of the parts finished and installed.
      we have been working on this for a while now.
      The Torque arm is virtually the same as what we have for the First Gen Camaro, so the performance is proven, same install , No floor cutting. if you are planning on running a 335/345 rear tire you will have to mini tub obviously, but that is IT. NO other modifications to the frame, trunk floor, back seat. Only the shock X member needs to be welded in.
      There is plenty of room for 3" exhaust over the axle.
      This is our new Second Gen Test car, it has the Chicane 9" floater rear in it as well as the StreetFighter front subframe.
      I will have some ride height pictures next week.
      Attachment 61940Attachment 61941
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Attachments don't work for me.
      St George Utah
      There thats better.
      Blake Foster
      435-628-4300
      St. George Utah.
      Austin, TX
      Daaaaaaaaaaang! NICE!
      Todd Longfellow
      Jul 2010
      Sacramento, CA
      Very pretty! Any chance you could get a shot of the back of the car facing forward? I'm just curious what the panhard rod's angles look like.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      May 2011
      Savannah GA
      Country Flag: Mexico
      Any option for the gm 10 bolt?
      St George Utah
      Quote Originally Posted by SLO_Z28 View Post
      that should give you a good idea. remember the suspension is at full droop. the panhard mount on the chassis has 2.5" of adjustment and the housing mount has 2 mounting holes with 1" of spread. there is 4" of travel which leaves 1" of clearance between the axle tube and the frame rail on full compression. there are 3 possible lower shock mounting positions to adjust the ride height ans 4 possible trailing arm locations to adjust the anti squat. the pan hard will normally be set up to be level at ride height.
      Blake Foster
      435-628-4300
      St. George Utah.
      St George Utah
      Quote Originally Posted by prosuperstar View Post
      we are working on it, we have done a couple prototype ones , actually just finished one yesterday on a 69 so we are not too far off.
      Blake Foster
      435-628-4300
      St. George Utah.
      Nov 2007
      Looks fantastic. Love the colour choice as well.
      Anybody out there installed the 12 bolt version in a second gen?
      Thanks,
      Apr 2014
      JAPAN
      Country Flag: Japan
      I will install a Speedtech torque arm on the 1970 Camaro. A leaf spring kit was also attached to the Detroit Speed ​​minitab, so the position of the leaf spring pocket is different from the standard. The Speedtech manual states that the spacer should be installed on the outside, but consider installing the spacer on the inside. However, the position of the trading arm is still different. Is there a problem?Name:  IMG_9941.jpg
