- Aug 2004
- Youngsville, NC
- 82
Advice Needed On Bearing Clearances
I am building an iron block 402 (LQ4 block). I am using King Engine bearings on both the rods and mains. The engine will be naturally aspirated and I am aiming for 450 rwhp. I know there are a lot of different opinions on this subject. The factory spec for an LQ4 is .0009"-.0025" on the rods and .0008"-.0021" on the mains. Some recommend following the rule of .001" X Journal Diameter, which means I should be aiming for .0021" on the rods and .0026" on the mains. I would like to hear from engine builders who have built proven street engines.
I am measuring the clearances with a 2-3" micrometer and a bore gauge with .0001" resolution. There is at least a couple of tenths of inaccuracy in my setup, but I am confident that I am in the ball park. Using a mixture of bearings, I have two possible options on both the mains and rods:
Mains:
Option 1: .0018"-.0021"
Option 2: .0025"-.0027"
Rods:
Option 1: .0018"-.0022"
Option 2: .0024"-.0026"
Based on real world experience, what clearances would you run? Am I over-thinking this and either set would likely hold up fine on the street? Thanks in advance!-Jesse
