    Results 1 to 13 of 13
      Central Florida
      67 Camaro w/ Mark VIII 2 speed fan
      Hey guys,
      I'm getting close to the point in my build where i'm going to make some decisions on a cooling
      system for a 67 Camaro. My question is... has anyone used the Lincoln Mark VIII 2 speed fan on
      a big block with short water pump. Just taking some quick measurements seems like it is going
      to be pretty tight or even possibly a no fit scenario. I have a Gen VI 454 with March Style Trac serpentine
      kit with the engine in stock location. I have the fan housing already trimmed as much as possible
      but yet still enough to make sure the blade doesn't make contact with the radiator core. Let me hear
      your experiences if you have used a similiar setup. Thanks
      BB
      Central Florida
      Nobody have this kind of setup ???
      BB
      Aug 2006
      South Dakota
      I don't have your exact setup but I had to drop the idea for the Mark 8 fan and went with 2 spal fans. If you need details drop me a line..
      Vail, Arizona
      dcfvgbhnj
      Dec 2009
      Austin, TX
      I have the Mark VIII fan running on my 69 Firebird with Pontiac 400 with March Serpintine kit. It is a very tight fit.
      I am getting ready to replace the radiator due to the factory one is leaking.
      Ray
      Jul 2009
      New Jersey
      It won't fit with a long pump, I know this for a fact. I measured my buddy's short pump and it was too tight for me to go buy everything and see. I know you will have to trim the fan housing some and it will still be tight. You can modify the rad mounts or go with the twin Spals. Crap cfm though. I have them. Speedway sells the Spals in an aluminum shroud for $249 or there abouts. A good variable speed controller is $100. If I had to do it again, I would spend more money and get a better rad and shroud combo. Be Cool and these fans leave a little on the table.
      RJ Cilurso
      67 Camaro with a few things bolted to it
      12 Camaro with a few things bolted to it
      50 Chevy 5 window p/u with a few things unbolted
      USAF
      Central Florida
      Quote Originally Posted by Protournova View Post
      Dropped you a PM
      Quote Originally Posted by AintQik View Post
      RJ,
      That's sorta where i'm at. I haven't decided on a radiator yet, but I already have the trimmed and ready (Mark VIII) fan. I was hoping to use this setup because i have used it in other builds (62 Caddy w/ 502 and AC) that traveled the 2010 Power Tour without issues. My thought process was if i could get it to fit and use the 2 speed fan (with good cfm capabilities) i wouldn't have to go and purchase such an extreme radiator like the 500-800 dollar units. I guess the only thing to do at this point is choose the radiator and see if it fits. Thanks for all the responses everyone
      BB
      Fredericksburg, VA.
      Does anyone have pictures of this Lincoln fan installed in a 1st gen?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Dec 2009
      Austin, TX
      Jun 2010
      Georgia
      Quote Originally Posted by AM.MSCL View Post
      Quote Originally Posted by Bad Bowtie View Post
      I can help with that. We offer a 2" thick radiator (available with or without or electric fan & shroud kit), which is the same thickness as a 4 core, and is USA made using USA-sourced materials, and is tig-welded by hand. It's all aluminum, no plastic or epoxy, and comes with a smooth top plate, and can be built with or without a trans cooler at no additional charge.
      Central Florida
      Well guys if anyone else is thinking about this setup, it didnt work for me. Ends up to be about 3/4 inch shy of fitting even after having the radiator tank as close as possible to the core support without touching. Next time i may modify the core support but unfortunately this one was already painted. Gotta get dual slim fan setup now. Build and learn
      BB
      Jan 2011
      I have a 1967 camaro with a bbc and the concept one pulley system. the water pump is the short style. you must trim the shroud as much as you can and install the mark Viii fan offset to the driver side as much as possible to avoid contacting the water pump pulley. it will fit and the fan is awesome. I use to have the black magic extreme fan but it just didn't cool enouigh, with the mark VIII it stays 180 degrees on the street and about 195 degrees on the highway. I have 373 gears in the rear and cruising at 75mph on the highway at aproximately 3200 rpm the temperature is a constant 195 degrees.
      Feb 2009
      muggy midwest
      From my experience, you don't even need to run a BBC spec'd radiator in your Camaro if you plan to run a Motorcraft style fan-you can go with a SBC drop-in aluminum replacement radiator and that will be fine. This will give you the added space required for the Mark VIII style fan to fit. The cooling efficiency of it being aluminum combined wiht the CFM pull of the fan is more than enough to keep your engine cool-I would go so far as to say the Motorcraft style fans allow you the option of negating using a BBC radiator alltogether-it just isn't needed.
      The shape of the fanblade is such that the fan creates a windtunnel of sorts and it just doens't have to move @ the same speed as any other fan to pull the same amount of air-for this reason, no other fan manufacturer can compete apples to apples with it-be it Spal, Flex-a-lite, Derale, Zirgo, etc. You name them they can't compete. And the same goes for LT1, LS1, RamCharger, etc. they can't pull the same numbers either. This isn't to say the other fans are not able to keep the car cool, but if you want the top dog-then there you have it!
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
