      Mar 2011
      Suspension for 2nd gen camaro
      Lookong at all the options and have narrowed it to two, either dse or ride tech. Which is going to sit the car the lowest and do any of them allow you to run negative camber? Also is the all new front subframe from dse worth the money? And lastly if ridetech coils or bags?
      Jul 2010
      Sacramento, CA
      For what you want to do with the car, the ridetech setup with air bags would be the best way to go. You can drop the car in the weeds and set the camber high, then fill up the bags and get a reasonable cruising height and get rid of some of that camber for just regular driving.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Mar 2011
      Quote Originally Posted by SLO_Z28:915191
      Sweet, and the system allows you to drive with the car as low as you want? Like does it allow you to cruise with the frame scrapping or is that a parked only function? Sorry if that sounds noobish, but i dont know much about air ride!
      Jul 2010
      Sacramento, CA
      You can manually control the air in each bag individually, and drive as low, or as high as you want. You can adjust on the fly too.
      -James
