Results 1 to 15 of 15
06-06-2012 #1
Rear sway bar advice for a triangulated four bar
Hey all,
I'm finally getting my car (67 camaro) on the road and I think I need a rear sway bar. The issue is nothing on the rear of my car is stock or a modern kit.
It's minitubbed (actually major-tubbed LOL) with 2x3" frame rails about 31" apart. The coilovers only have about 28" of seperation (which I'm sure is contributing to the body roll)
I've been thinking that a splined rear bar mounted between the frame rails in front of the axle is the way to go, but wanted an opinion as to if the top of my shock mounts would be a good to connect the end links of the sway bar? You can see a pic of the mount below.
I'm hoping the shock mount would work as the rear axle is now powdercoated, so I'd rather not weld on it.
Or is it possible to get a custom "bent" bar made? It there an advantage to one over the other? Opinions?
Thanks!
Jason
06-07-2012 #2Most sway bar companies will build a custom bar for you. It isn't cheap, but it may be the only way to go. You can always use splined bars too, which can be more flexible in terms of packaging, but are expensive and heavy.
Where is your roll center? That will play a big role in bar size.
BTW, who bent those rails?Matt Jones
Mechanical Engineer
Art Morrison Enterprises
06-07-2012 #3
