      Melbourne, FL
      69 T/A wing for 67/8s ??
      Anyone have a lead on a good wing for 67/8s ??? The one from the parts place is a three piece fiberglass item. Anyone know anything about the quality ??? I purchased an ABS one many years ago that was very rough on the surface and sagged some. I'd like to find a solid version that doesn't sag.
      Or, a good three piece 2nd gen wrap around that fits a 1st gen.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Mountain Springs, Texas
      The Part's Place one is not too bad. I did carefully add some expanding foam inside the wing to try to help keep it from sagging. It seemed to work. Trick is to not use too much or it will bulge when the foam expands.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Melbourne, FL
      Thanks. Interesting idea ...
      Jun 2010
      Hi Mark, off topic, but have a link on the pulleys you used on your engine?
      Melbourne, FL
      The setup was from Rodney Red radiators. Not sure if they still make these. Was a nice simple inexpensive setup.
      Oct 2008
      Brisbane Australia
      Hi,
      I'm planning on getting a 69 wing for my 68. What did you end up doing? A few choices at present, Glass from Ames and The Parts Place and ABS from Performance years and Firebird Central.
      Cheers.
      Brooke
      Brisbane Australia
      Brooke Fraser
      Brisbane Australia
