    Results 1 to 12 of 12
    Thread: Relay Mounting?
      Woodbine, MD
      Relay Mounting?
      I am wiring up my radiator fan and my trans cooler fan and don't want to just mount the relays on the fender close to the battery.
      What have you all done with mounting your relays?? Pics would really help!!! Thanks!!
      The current state of my poor car...
      Douglas Lutes
      1988 Monte Carlo SS
      Mar 2004
      Mid-Michigan
      https://www.pro-touring.com/showthre...ight=relay+box
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Woodbine, MD
      perfect!!!!
      Douglas Lutes
      1988 Monte Carlo SS
      Sep 2008
      Jacksonville, Florida
      2005 and down Chrysler PT Cruiser use a 4 relay box that is located behind the engine mounted junction box, but is separate. Sorry no pic. The junction box is pretty handy as well for fused outputs.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      www.cjdautomotive.com
      Sep 2008
      Sorry, I mean Sebring. I'm working on a PT now and have it stuck in my head.
      Craig Scholl
      CJD Automotive, LLC
      904-400-1802
      Aug 2005
      Hamilton, NJ
      not for fans (I use a DCC), but for headlights, hei, etc. I use standard relays and have them on a simple bar on the LH inside of the rad support. I keep a spare on there too. I like these because they are easy to procure no matter where I am.
      all the hardware is stainless, even the star washers. the mounting studs act as ground posts.
      Scott from NJ.
      Vent Windows Forever! ...
      Metamora, Illinois
      Check out my build thread post #64. I am building my on fuseblock/relay panel using a Coope Bussman RTMR panel. It will hold 5 micro relays, 10 fuses and is extremely compact. Here is a direct link https://www.pro-touring.com/showthre...98#post8996984
      Rolla, MO.
      I'm using the same bussman panel in my Malibu. I have it mounted behind the driver side headlight where the evap canister was. One relay for each fan, one for low beams, one for high beams and one for the fuel pump, along with a fused source for each with five extra fuses for future use. The panels are cheap it's the "extras" that you need that hurt lol
      Matt
      1980 Malibu, off the jackstands.....let's see if a T-56 will last longer than a TH-700R4
      Woodbine, MD
      thanks for all the responces!!!!!!
      Can the relays be mounted a lil ways away from the battery? Mine are currently mounted right next to the battery.
      Douglas Lutes
      1988 Monte Carlo SS
      Metamora, Illinois
      Quote Originally Posted by SicMonte View Post
      Yes...most of my relays are in the engine bay with a couple under the dash. Just make sure you use the proper gauge wire and fuse your circuits properly.
      san diego
      Feb 2002
      Santee, CA
      I mounted a few of my relays on the core support under the fenders (fans and electric brake pump). Like Rocketrod said, you need to make sure you run the proper gauge wire, but for out of the way locations (like under a fender), I prefer to run a breaker instead of a fuse.
      Most of my relays I have mounted in my kick panels. On the Camaro you can fit 4 per side:
