      Las Vegas, NV
      LS1 engine LS6 intake , LS cam, Vortec parts
      - I have a complete LS1 / t56 dropout from a 2000 WS6 Trans Am (F-Body Camaro SS Z28) that was adult owned and maintained
      *only the engine is available* (trans is not)
      the engine is stock with no aftermarket modifications ran excellent prior to removal
      The complete LS1 engine assembly includes:
      factory LS1/ M6 engine harness and pcm (#09354896, harness needs a few wires repaired)
      all front engine accessories (f-body) alternator, p/s pump, a/c compressor, water pump, tensioner & idler pullies
      stock LS1 intake assembly with dbc (drive by cable ) throttle body
      stock F-body exhaust manifolds w/ egr tubes (have y-pipe available)
      starter
      all ignition coil packs & harnesses
      all engine sensors
      will include flexplate for auto transmission (4L60E)
      also have F-body (Camaro / Firebird) positive / negative battery cable harness
      SOLD!!!
      - Factory LS6 Intake assembly complete
      part# 12573572
      complete with fuel rails, injectors, map sensor, seals and throttle cable bracket
      This intake is a great upgrade for a LS1 or Vortec series truck engines (ie 4.8l , 5.3L , 6.0L LQ4 , LQ9 , etc)
      ready to bolt on
      asking $500
      - Brand new in box Texas Speed / Comp Cams Tsunami camshaft
      for gen3 LS / Vortec series engines
      This cam is brand new, just out of box for pics
      retail for $389 + shipping
      specs.
      valve lift (int/exh) 647/608
      dur. @.050 (int/exh) 235/240
      LSA 111.0
      asking $350 obo
      - pair of low mileage (28k) cylinder heads and Intake manifold setup off a 2000 C5 Corvette LS1 engine
      Cylinder Head Casting # 853 cathedral port the heads are complete with rockers , stands, valves, springs, etc.
      SOLD!!
      - complete set ( for two heads) of low mileage (40k) rockers and stands from a 6.0L (will work on 4.8L, 5.3, 6.0 LS1, LS6)
      $60 for both
      - one set of 8 brand new GM L92 intake valves 2.165" part #12590771
      $30 for set of 8
      - stock LS1 "spider" coolant crossover tubes (4 port) used in good shape (2 available) SOLD!!
      SOLD!!!
      - complete 2002 LQ4, LQ9 6.0L / 5.3L truck intake setup, with (65k miles) complete with fuel rails, fuel injectors
      asking $75 obo
      most parts will fit various LS1, LS2, LS3 , LS6 , 5.3, 6.0 L92 engines used in street , pro-touring , offroad sand rail and drifter , drift cars
      In Las Vegas
      call (702) 677-4085
      Do you have a pic of the coolant cross over tubes?
      Las Vegas, NV
      coolant tubes
      I already sold one, here are pics of the other one
      please let me know if you need additional
      thanks, Jeff
      ill take the coolant tube. Do you still have the t56?
      Las Vegas, NV
      Quote Originally Posted by stangs400 View Post
      pm me with your location for a shipping $
      Yes, I still have the T56
      Las Vegas, NV
      LS1 engine is SOLD!!
      LS1 cyl. heads are SOLD!!
