05-04-2012 #1
- Nov 2004
- Gilbert, Arizona
- 50
Rear disc brakes from 95 Z-28 on a second gen camaro
I am sure that this question has been asked before, but I just can't seem to find enough information on it. I have the rear setup from a 95 z-28 and would like to install it on my 79 z-28. I know that I need to have 2 of the same side caliper. Not sure which side it is, but from the pictures that Baer I should have the correct one. I need to know if I can use the stock mounting plates and what emergency brake cables I will need for the correct lenght. Any help is appreciated. Thanks
Z-28 has a built 383SBC. The heads are AFR 195 CNC ported with a 274 Solid Extreme Energy Cam. 1.6 rockers an Edelbrock RPM Air Gap intake and a 650 Holley carb. Turbo400 with a 10" ATI convertor 3200 Stall. 3.42 posi. Hotchkis springs/swaybar/UCA and Bilstein shocks.
