      Sep 2007
      What size wheel studs should I go with?
      I'm running 17x8's on the front with 17x9.5's on the rear. Hotchkis TVS, C5 front setup, 4th gen F-body rear coming soon.
      Want to do new wheel studs from ARP or the like.
      What size do I need or should I go with?
      Thank you for any advice,
      Donnie
      Mar 2004
      Mid-Michigan
      Stuffing in 1/2" studs is easy enough but first check your wheels for required length. I ended up with some Ford studs to get the length I needed for good lug engagement over the Corvette rotor. I tried Astro van studs at first but they were way to short.
      The studs I used had a knurl shoulder that was a tad to long and stuck up past the wheel mounting face on the hubs. I ended up drilling out the Corvette rotor so it would slide over that shoulder. It wasn't much but it will have to be done to the new stuff when replacing rotors.
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Sep 2007
      Thank you sir.
      Donnie
      Mar 2004
      Mid-Michigan
      No problem Donnie,
      Here are the part no.s from Summit for the lug nuts and studs.
      GOR-91984 6 LUG INSTALL KIT 1/2 -20
      RNB-610-523 WHEEL STUD (10 PER BOX)
      Mark:
      Sep 2007
      Quote Originally Posted by astroracer View Post
      No problem Donnie,
      Thank you so much!
