    Results 1 to 11 of 11
      Jul 2011
      NC
      C6 power seats wiring diagram?
      Anyone out there have a wiring diagram for C6 power/heated seats?
      Josh
      "Schism"
      69 camaro
      Josh,
      C6 seats are extraordinarily complex. See this post on our blog:
      http://blog.iimuchfabrication.com/?p=85
      They have a seat controller, plus wiring for the side impact airbag, seat heater, etc. All connected to the BCM for integration to other systems. If you want more information, the best idea is to purchase the official GM books. I can help you with that if you wish.
      ​John Parsons
      Oct 2010
      Santa Ana, CA
      I found it once ill try looking for it, but the power is simple just black and red/white wires, see the link below hope it helps, What kind of car you putting these in? I got em on my 68 camaro (project) still thinking of choping a few inches of the headrest tho there kinda higher then i thought they would be.
      http://www.kawal.net/power%20seats.htm
      Havii Gonzalez, OC Calif.
      68' MARO - UNDER FULL RESTO - LSX ect..
      Used to be known as stilo
      Jul 2011
      NC
      Thanks guys,
      Going in my 69 camaro. Have them mounted & the fit couldnt be better!!! Love them! Just want to hook up the pwr & heaters- no airbags... Were u able to get them workin good stilo?
      Josh
      "Schism"
      69 camaro
      Oct 2010
      Santa Ana, CA
      I only tested the power tracks not the heat, i already have them sitting in my car but im still a long away from driving it
      Jul 2011
      NC
      Did you use the GM connectors or cut them off and hardwire directly?
      Josh
      "Schism"
      69 camaro
      Jul 2011
      NC
      Thanks John,
      I read your link above and that mainly talks about switching other seats into a vette.
      I'm using the stock C6 seats into a camaro and would like to only use the power and heat- no BCM or bags. Do I need to trick the actual Seat or plug the airbag wire somehow so it doesn't fire? Will the belt pretensioners work still?
      Josh
      Josh
      "Schism"
      69 camaro
      Oct 2009
      Power seats
      Did you get it figured out?
      I think I've gained enough knowledge on how to hook these up. Does your driver seat have a memory module (black box directly under the cushion held on by tabs under the spring? the wiring for memory (I am pretty sure) just needs another power supply hooked up to the memory module (red/white) that normally gets power from the body control module. Or, what I did, was gut the memory module out and all the extra wiring and wired the 6-way switch just like the passenger side (switch direct to the motor plug), but it will require larger gauge wire.
      Quote Originally Posted by diesel25lrs View Post
      Thanks John,
      Josh
      Jul 2011
      NC
      No, haven't done my wiring yet...That link that stilo posted above has a pretty good diagram from what I can tell. Please let me know how yours works out!
      Josh
      "Schism"
      69 camaro
      Oct 2009
      Seats
      The kawal site helped tremendously. Ray is a great guy and is willing to help.
      I got my power seats to work great in my 68 Camaro. I yanked the memory module out and straight wired the motors. Put in v6 heater switches and those work good. To use the memory seats, you can do it in a non memory car, but you need to have the corvette body control module, but too much effort.
      Jul 2011
      NC
      Got them all hooked up and working properly.....very simple- red/white power, black ground and wha la!
      Josh
      "Schism"
      69 camaro
