      Mar 2010
      Alabama
      Victor E intake help
      I bought a holley hp retrofit kit. I bought a edelbrock victor e intake and rails. My throttle body provided by Holley is hits rails or the throttle parts is. Looks like I will need a 2" spacer to clear rails. has anybody else ran into this problem? Also the places for the injectors on intake stick out in the way of the valve cover. has anybody ran into this problem?
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Mar 2010
      Alabama
      Attached is picture of spot that gets in way of valve cover.
      David Butler
      Jun 2005
      Lynnwood Wa.
      I don't think it will hurt anything to cut the edge back a small amount . There appears to be enough edge margin to the injector holes
      to bevel the edge back.
      Can you post a photo of the injectors, fuel rails and throttle body in stalled to give us an idea how much clearance you need.
      Perhaps you could use shorter injectors.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Mar 2010
      Alabama
      yeah I don't have injectors yet. I have mounted rails with their mounting brackets. Looks like I will need a 1 1/4" spacer to clear fuel rail.
      David Butler
      Jun 2005
      Lynnwood Wa.
      Check out LS1Tech.com in the Fueling and Injection forum. There are vendors who offer all kinds of injectors, and adapters.
      WWW.ls1tech.com
      Oliver Shultz
