07-15-2005 #1
- Dec 2004
- 27
Sputtering when stomping on it...??? Help..
I have a weiand 144 on a 400 sbc which runs fine under normal to medium throttle, but really begins to sputter when i stomp on it. I'm running around 8psi of boost w/ the blue holley fuel pump, fram race filter and holley 750 vacuum secondary. I can't seem to figure out what the real prob. is although i keep tweaking the jets and timing but haven't gotten it fixed yet.
Thanks for the feedback in advance.
RyanLight the fires and smoke the tires!!!
07-15-2005 #2
07-15-2005 #3
- Aug 2004
- Milwaukee, Wi.
- 327
My vote is to go to a 750 with mechanical secondaries. Boosted motors need LOTS of fuel! The vac. secondaries don't have jets that you can change.Make sure you check your fuel pressure under boost so you don't go lean. (detonation= bad, see BIG KABOOM!)
Steve
07-21-2005 #4
- Dec 2004
- 27
problem solved. I manifold referenced the power valve. charger was sucking power valve closed. fast as hell now. thanks, and if anyone has same prob. drop me a line i'll let you know how to do [email protected]
later.
ryanLight the fires and smoke the tires!!!
