Thread: oil pan hitting crossmember
03-20-2012 #1
If it wasn't for bad luck I wouldn't have no luck at all. Engine is back in (the first time the hooker "stock" location plates wouldn't allow me to mount the engine as the heads made contact with the firewall), harness is finally back and installed, booster is in and I thought I was about to put the headers in. That's when my buddy noticed the oil pan was making contact with the frame. I used the 1.5" forward plates. The oil pan had a bit of clearance when I first installed it but it seems to have settled. Maybe I just thought I had clearance. Either way, holley said the plates worked with the oil pan. So here's the question: Can I make 3/8ths plates to sit under the motor stands or are there taller stands than the regular sbc stands used in the 68 camaro that would work or that I should be using?
thanks
Scott
____________________________________________
Scott
