    Thread: Copper in oil
      Feb 2009
      homestead, fl
      Copper in oil
      Long story that I will try to make short.
      Forged my motor, ran it for 100 miles, changed oil and filter. Swapped in 80lb injectors and took about a tank of E85 to get it dialed in from AFRs in the 9s to 11.5.
      Went to the track and put in a few runs with a couple back to back.
      Did a speed run upto 160 leaving the track. Following day while in traffic noticed low oil pressure. Pulled oil and filter has the stuff in the above pic. Oil smelled like E85.
      Cold idle before I replaced oil.
      http://www.youtube.com/watch?v=OAhWw...e_gdata_player
      After i swapped oil and filter cold idle
      http://www.youtube.com/watch?v=SUIkM...e_gdata_player
      Operating temp
      http://www.youtube.com/watch?v=CSGZt...e_gdata_player
      Replaced the oil and it seems to be back to normal; going to pull the filter tomorrow and check if particles are less.
      Here's my theory: E85 ran too rich for too long and drag racing wore out a bearing. The car makes its normal noise which makes me believe if oil pressure returns to normal and copper specs are reduced to normal levels I can drive my SS for a couple thousand miles before I pull it apart for inspect and repair. Your thoughts please...
      69 Camaro under the knife
      72 Charger in paint
      02 Camaro Turbo own the road
      Dec 2011
      Planit Oahu, Hawaii if you don't belive me check shipping prices
      send a sample to a lab.
      if you think you have bad bearings, whether or not if making noise change them now and save yourself some money and replace them now!
      California
      If your getting that much of a concentration of copper in your oil there is no way its from a single bearing and if it is there probably isnt anything left of the bearing. I would tear it down!
      Auburn, CA
      Tear it down! You seize a main or rod bearing your done.
      Tim Tracy
