    Results 1 to 18 of 18
      Sep 2011
      Eagle Point, Oregon
      idiots guide to shocks
      In my search for shocks for the front of my 69 camaro wanna be p-t/autox budget build I had to admit that I know a lot less about them than I would like to admit as a life long "car guy". The proof coming from to me from the fact that they can be $20 or $2000 for a single shock (possibly more), they even have dyno's for shocks! My hope from this thread is a "sticky worth" compilation of information on shocks, both coilover and not, single adjustable, double adjustable, triple adjustable, price, advantages/disadvantages, who makes what, etc.
      I see that single adj. shocks adjust only the rebound? I would have thought compression would have been more important but I guess thats the springs job? While the double adj. have comp/rebound, and triple have 1-rebound/2 compression?
      And aside from ride height adjustment with coil over shocks are there any other advantages or disadvantages? To put "true" coilovers on my 69 it looks like I have to buy a kit like DSE or ridetech chicane (although I plan on asking about this in another post).
      Is rebuildable important? how long should a shock or coilover last and what are the signs they might be going out? Anyways I think you get the point, and I am hoping that some of you will chime in and help me (and hopefully a lot of others) out
      Oct 2009
      New Derry, PA
      Quote Originally Posted by john55blaze View Post
      Single adjustable shocks can either adjust rebound and compression equally, or one or the other (typically rebound as you pointed out). The adjustments are nowhere near as important as the main damping curve. That still has to be right for the corner weight, spring rate and wheel motion ratio.
      Oct 2011
      Philipsburg, Pa
      I have some QA1 damping curves I'll post. This thread could get huge.
      ramey
      Technical Support
      UMI Performance, Inc.
      [email protected]
      814.343.6315
      Join us on Facebook!
      Des Moines, IA
      I can go on and on regarding the aspects of shock absorber design and application, but it will take forever.
      If you want a really well written, in depth look at everything I suggest reading this (it's focused on off road, but the basics still apply):
      http://www.pirate4x4.com/tech/billav...lovers/Part_1/
      Here's a quick summation:
      What is a shock absorber?
      -The main purpose of the shock is to control and slow down or stop the oscillation of the spring. This keeps the tire in contact with the road.
      -A shock is a timing device. . .it controls how quickly or slowly the wheel and tire move into the body (compression) or back to the pavement (rebound).
      -Typically the spring does most of the compression "work" while the shock slows down the rebound (or the spring wanting to return to free height).
      -A shock is a radiator. . .it turns suspension motion into heat and must be able to keep the oil at a proper temperature. If the oil becomes too hot the viscosity changes and the damping effect is lessened.
      How does a shock work?
      -A piston moves through a column of oil. The oil forces valves open. This force is controlled by the design of the piston/valve. The motion is transferred into heat through the oil.
      -As the piston moves into the shock (compression) the volume of the shock rod must be displaced (remember, the oil is a "solid" and cannot be compressed) so the oil has to move to accommodate the volume of the rod.
      There are basically two types of shock designs used today, twin tube and monotube.
      Twin Tube:
      Twin tube shocks have two tubes. One is the larger outer tube you can see which holds oil (and typically a plastic bag filled with nitrogen). The inner tube is smaller and is where the piston resides, which actually does the damping.
      As the shock is compressed the rod moves into the shock and the oil is moved through a base valve at the bottom of the shock where it turns 180-degrees and moves up the outer tube.
      Pros:
      -inexpensive (though they use more parts 50 years of cost reduction by OEM suppliers has dramatically lowered the overall cost)
      -short packaging (extra oil and the nitrogen are stored around the inner tube)
      -rebound and compression knobs can be located on the bottom of the shock.
      Cons:
      -smaller piston means less surface area and therefor less damping capability
      -captures heat (heat is created as the piston travels through the oil. Since the piston is enclosed by a second tube with oil around it the heat cannot be dissipated as efficiently as a single tube)
      Monotube:
      Monotube shocks have a single tube. The piston rides on the inside of the tube you can see, and is therefor much larger than that of a twin tube. There is a separating piston close to the bottom of the shock, which separates the shock oil from the nitrogen. The nitrogen keeps pressure against the oil so the piston is always travelling through oil, not an oil and air mixture. As the shock is compressed the rod moves into the shock and the oil column forces the dividing piston to move down the shock tube. The oil does not really "flow", it just moves the same volume as the shock rod.
      Pros:
      -larger piston for more control area
      -cooler operation (the oil is contacting the tube which is directly touching airflow, and will therefor not get as hot and has the ability to cool quicker than the twin tube)
      Cons:
      -longer packaging (since the nitrogen has to go under the oil column the shock must be longer. . .unless you use an external reservoir)
      -rebound adjustment is through the shock shaft, while the compression adjustment must be put on a reservoir
      -damage to outer tube could potentially destroy the shock as the piston or dividing piston is no longer allowed to move on the ID of the tube
      This is some VERY basic information about shocks in general. I'm sure we'll get much more in depth in this discussion, so we can address the more technical questions later.
      Dec 2009
      And if you want to go down the rabbit hole, here's a good thread on shock tuning ideas, shock dyno curves, etc:
      http://forums.corner-carvers.com/showthread.php?t=41374
      Oct 2009
      New Derry, PA
      Quote Originally Posted by marolf101x View Post
      Pros:
      Cons:
      Monotube:
      Pros:
      Cons:
      -rebound adjustment is through the shock shaft, while the compression adjustment must be put on a reservoir.
      Another potential problem with monotube shocks... ANY damage to the outer shock body will usually ruin the shock, as there is no insulating layer between the outer body and the piston.
      Des Moines, IA
      Ray,
      Good point. I added it to the "cons" of the monotube design.
      Oct 2009
      New Derry, PA
      To add a little to the "adjustments" mentioned earlier...
      "High" and "low" speed refers to the speed of the shock shaft during a given suspension motion. High speed is typically 3"/second or faster. Low speed is less than 3"/second shaft speed. "Progressive" and "Digressive" damping refers to the change in resistance above 3"/sec.
      Single adjustable: Compression/rebound adjust together (may or may not have external knob), OR only rebound is externally adjustable.
      Double adjustable: Compression and rebound stiffnesses adjust separately but across entire shaft speed range.
      Triple adjustable: Has separate high and low speed compression or rebound, but single (full range) adjuster for the opposite motion.
      4 way adjustable: Separate high and low speed adjusters for both compression and rebound.
      Some manufacturers include ride height or spring preload adjuster (coilover) as one of the adjustments, but the industry standard refers only to the damping adjustments of the shock absorber itself.
      Indiana
      Quote Originally Posted by exwestracer View Post
      True...but in reality the material thickness of MOST monotube bodies would prevent internal damage unless it was a severe impact. Normal, and even heavy, road trash would not damage the shock. You would have to be in an accident of the magnitude that would likely damage a twin tube as well.
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      san diego
      Bret,
      Can you supply a shock dyno sheet with each shock?
      Des Moines, IA
      Sorry, I missed this thread (thought I was subscribed). I'll get some Dyno sheets up Monday when i'm back in the office.
      Des Moines, IA
      As promised, here are the graphs for the NA, SA, and TA shocks.
      3.6_NA_large.pdf
      3.6_SA_large.pdf
      3.6_TA_large.pdf
      ***Edit Note: I decreased the range of the graph so they are easier to see.***
      Nov 2010
      Antelope Valley, SoCal
      I have been hoping something like this would come up. Subscribed! Anyone have any input or a good link for selecting coilover length?
      Des Moines, IA
      ridetech.com, perhaps
      Oct 2011
      Philipsburg, Pa
      Double 0-18 every other click SD.pdf
      NA SD.pdf
      R series 0-18 every 3rd click SD.pdf
      Single 0-18 every 3rd click SD.pdf
      Here are the QA1 Dyno curves.
      ramey
      ps not sure why one is a jpg and the rest are inline but there you go
      Technical Support
      [email protected]
      814.343.6315
      Oct 2009
      New Derry, PA
      ^^^Good Stuff! ^^^
      For shock newbies, "up" from 0 on the graph is compression motion, "down" is rebound (extension). The descending force curve (as shaft velocity increases) is called "digressive" damping.
      Apr 2012
      Don't your shocks have a lot to do with what you are doing with the car? A big fat pig car in autocross usually wants to squat and stick for acceleration out of the corner, I don't know about drag race... Road race is a little different, street is different again...?
      Des Moines, IA
      that's why we have lots of knobs on the shocks! ;)
      Shocks are just a timing device. . .they do not control how the car moves. . .they only control how quickly or slowly the car moves in a certain direction (the car is going to move where it wants, all you can do is control that movement).
