    Results 61 to 79 of 79
    1. #61
      Apr 2010
      Portland, OR
      Geno,
      That is a nice clean setup you have there!!! Whats even more awesome is that we both have wires hanging down and no HVAC controls ;)
      1973 Firebird 466 Pontiac, T56, C5 Brakes, PTFB and Hotchkis suspension
      2011 Camaro SS Supercharged, ZL1 body and brakes, Z28 suspension.
    2. #62
      Mar 2010
      Valencia, CA
      Quote Originally Posted by 70Uglybird View Post
      Geno,
      Bobby,
      I like yours too- I wish I had gone the GPS route, but already had half of the Autometer gauges so I was pretty much committed to them. A/C will be the last thing I do to my Bird, but living in SoCal it's a must.
      The 406 Pontiac in my Bird now runs well- so good I'm in no huge rush to get my 455 in the car. I finished the shortblock over a year ago and decided I would go all in with the heads and cam instead of just running iron heads and an HFT cam. The 325 cfm SD Performance e-heads and their Road Paver solid roller cam will make around 600 hp, so do you think it's worth going for the newer TR-6060 trans vs. an earlier T-56?
      Geno
    3. #63
      Apr 2010
      Portland, OR
      I'd go with an earlier t56 from a gto or ctsv. The guy who owns t56rebuilds is a really good friend of mine if you get a core he will make it perfect for your car. The newer ones have a bigger case.
      Spend the morning installing this, need to get the low pressure return line hooked up and then I'm looking forward to finally having good brakes after three years!!!!!!!!
    4. #64
      May 2014
      How did you wire the alpine stereo in your car?
      RMP- Rolling Mean Power
    5. #65
      Apr 2010
      Portland, OR
      Wow can't believe I haven't posted an update since 2014! Where has time gone! The car ran but the fuel lines oozed fumes and anytime it got over 78 degrees outside it would over heat when I got stuck at a stop light. So I may have put a few hundred miles. Decided to just go all in on the Pontiac thing and added:
      SD Performance KRE heads
      SD Performance Stumpuller custom ground for EFI
      Holley Terminator with Distributor to electronically control timing
      Got ahold of the Tribal tubes guy and had some headers made (he is in state)
      Restomod tank with 5th gen module and vapor works
      All new fuel line and 6AN flex line.
      Black CVF serpentine kit
      Vintage Air
      Harland Sharpe Lightweight Rockers
      Here is the motor now!
      Tank
      Name:  resto mod tank.jpg
    6. #66
      Apr 2010
      Portland, OR
      So before putting tank in I had to deal with this some how
      Name:  rear before.jpg
      Have rust here and after that its just in the "dog house" Up front drivers side. Was in the middle of looking at temp solutions and did the Covid thing and bought a house with 2 acres but had no shop. So while I was building a 48x 36 shop I had to get storage for some cars. Why not get some work done so send it off to Graceful Kustoms in Eugene.
      Out with the old:
Size:  339.4 KBName:  rear floor.jpeg
      New trunk with a door, I'm guessing that the door will not be popular Wasn't an easy decision but with all the stuff going on with the pump etc I had it cut.
      So did new powder coated subframe for car with Speedtech streetfigher setup, DSE steering box and Wilwood brakes. I had to go 4 piston for now because I can't get the 6 piston setup.
      Name:  front assembly.jpeg
    7. #67
      Apr 2010
      Portland, OR
      At this point the Project is way delayed as the shop ended up moving to a bigger setup. But that did give me time to finish my shop. Really a dream come true can't wait to get it all dialed in so I can actually use it!!
Size:  329.0 KBName:  shope extra lift.jpg
      Picked up some Recaros which I'm pretty excited about!
      Car was on the ground to be picked up!
      Name:  on ground.jpeg
      Made it home and got it on the lift!
      DSE mini tub
      Speedtech Torque arm
      Moser 9inch with 3.50's (466 Pontiac with GTO T56)
      Wilwood brakes the 4 piston 13 inch rotors
Size:  53.5 KBName:  Finish rear1.jpg
Size:  328.8 KBName:  ta1.jpeg
Size:  13.6 KBName:  Torque arm.jpg
    8. #68
      Apr 2010
      Portland, OR
      Attachment 191443
      Front end
      Attachment 191444Attachment 191445Attachment 191446Attachment 191447
      Need to finally get ahold of Zak at Boze and order my wheels. 95% settled on these:
      Attachment 191448
    9. #69
      May 2012
      Kansas City, Missouri
      What a awesome garage. I'm jealous.
    10. #70
      Apr 2010
      Portland, OR
      Quote Originally Posted by thumper877 View Post
      Thank you! It was quite the ordeal to get it built during all this craziness, time wise and went way over budget. But really a dream come true, what's crazy is that I feel like I'm already running out of room! But the El Camino is my dad's I'm finishing up a LS3\t56 Magnum install and when that is complete it will free up quite a bit of room! That is a BIG car!
    11. #71
      What a fleet man!! That shop is amazing man. I forget that you have a bad Firebird too.
    12. #72
      Florida
      Looks like things are going well!!! I like the trap door in the trunk!
    13. #73
      Apr 2010
      Portland, OR
      Funny not sure if you remember you gave me advice NOT to go crazy. Tried to listen but ran into some snags and one thing led to another. I'll be installing a set of your Engine mounts with the 466 this weekend!
    14. #74
      Portland, OR
      Very nice!!! I'd be interested to hear what you think about the speedtech torque arm. Been thinking about it.
    15. #75
      Sep 2019
      I'm really enjoying this build and it's providing inspiration while I map out the build on my '70. I'm planning to go EFi 400 stroker and TKX and now I've seen yours, the trapdoor in the trunk floor has been added to my list of must dos! Hoping I can get back to the US soon (I'm in England) so I can at least pack a few parts in my suitcase and save some shipping costs!
    16. #76
      Florida
      See what happens? AHAHAHA
      Get the engine installed?
    17. #77
      Apr 2010
      Portland, OR
      Nope I got side tracked with vintage air install! Always something!
      - - - Updated - - -
      Quote Originally Posted by 4mul8ion View Post
      Very nice!!! I'd be interested to hear what yo5u think about the speedtech torque arm. Been thinking about it.
      You should come over and check it out!
    18. #78
      Apr 2010
      Portland, OR
      Hope these are wide enough!Name:  20211230_163829.jpg
    19. #79
      Portland, OR
      Looking good.
