      timken bearing play
      I am installing new timken tappered bearings in moser 12 bolt w/ big ford ends, new style. After torquing bolts down to 35ft-lbs I get .008" of end play, about the same as I had with the roller bearings (after 8 auto-x's and 1 track day). I plan on picking up 12 bolt carrier shims tomorrow to try and get rid of some of the play. The question is how much play should there be? Leave a little end play? Shim until I get Zero? Or shim until zero then add another shim to pre-load the bearing?
      I have the wilwood floating caliper set up and using wilwoods retainer.
      Pete
      Aug 2005
      Floyd, VA
      Is this a hot or cold measurement? If it is cold, take that measurement and subtract the hot measurement to get a ballpark of how much shim you want to zero it out at operating temps without bind.
      Politicians need to learn to be Americans instead of Republicans and Democrats
      If you are not part of the cure you are part of the problem
      12/22/2012: I remember the end of the world like it was yesterday
      Central CA USA
      A Timken bearing is a tapered roller bearing. Did you switch from a BALL bearing to Timken?
      Quote Originally Posted by David Pozzi View Post
      Yes, switching from sealed ball bearing to timken tapered roller bearing. Sorry for some reason I picked up the term roller bearing for the sealed ball bearings.
      I talked to another member on the forum who has a little play and hasn't had any issues with it, so I think I am just going to with what I got. The carrier shims did not fit anyway, ID to small.
      Pete
      Central CA USA
      I think the ball bearing will maintain less end play for a longer time than a tapered roller bearing. I don't see any way to shim the inboard axle on a Ford wheel bearing & reduce end play.
