Results 1 to 10 of 10
07-11-2005 #1
General front suspension install questions...
Gents,
I've started to install the full GW front set up on my A-body (upper As, springs, lower dels, new sway, etc.). The engine is out of the car, so I have no idea of actual ride height with the new springs (S-5). I'm also installing the Baer Track system with B-body spindles.
(1) Other than the sway bar having to be set up and torqued while the vehicle is on the ground, are there any other components that I can't torque while it's "on the rack"? Will the engine not being installed be a problem for properly setting it up?
(2) After the install, I measured the left and right front from the ground to the lower edge of the wheel well. I come up with the passenger side as being maybe .25" taller than the drivers side. Should I worry at this point? Mind that the engine is not installed in the car so I have no idea how much the srpings will settle once I reinstall the engine. I seated the springs in the bottom perches per GW recommendation the same for both sides.
Thanks in advance for your input.1965 GTO - 439ci Pontiac ,66 Tripower induction, M-20, Full GW suspension, 3:1 PS, manual Baer 13"/12" disks, 18" AR TT2 "Classics"
2005 GTO - chrome lugs and valve caps...
