    Results 1 to 11 of 11
      Jun 2009
      Central FL
      LS1 Rear caliper conversion brackets
      So I need to change my rears to a staggered setup for the staggered shocks.
      I'm having trouble finding someone that sells the metal conversion bracket, opposed to a full backing plate with parking brake hardware. It would be even more awesome if someone sold just one bracket.
      Dan
      1968 Camaro v2
      LS6 :: Viper T56 :: C5 Brakes :: Hotchkis Suspension
      Jun 2009
      Central FL
      Will this clear the LS1 rear rotor?
      http://www.hawksthirdgenparts.com/90...rordriver.aspx
      Dan
      1968 Camaro v2
      Aug 2005
      Hamilton, NJ
      i don't know but that bracket is for an entirely different caliper setup
      Scott from NJ.
      Vent Windows Forever! ...
      Jun 2009
      Central FL
      I thought it might have been to adapt LS1's to a third gen.
      But what I'm looking for should look like that, but clear a 12 inch LS1 rotor. Am I just nuts and no one makes one? I've been looking for 2 days.
      Dan
      1968 Camaro v2
      On the LS1 rears ('98-'02 f-body) the backing plate is separate from the caliper bracket. The parking brake actuator mount is part of the caliper bracket, but I don't see why it couldn't be removed.
      Bob.
      Jun 2009
      Central FL
      Quote Originally Posted by a67 View Post
      Bob.
      I need to mount the caliper on the other side, and the bolts to the rear axle housing wouldn't line up.
      Dan
      1968 Camaro v2
      Quote Originally Posted by Vicinity View Post
      Get two of the same side (right or left, whichever is required), and use them. That will put one caliper forward and one toward the rear. And the top bracket to axle tube bolts are on top on both sides.
      Note that the stock LS1 calipers are mounted toward the front of the Camaro/Firebird.
      Bob.
      Jun 2009
      Central FL
      Bob.
      I was hoping someone would sell just a single bracket so I didn't have to buy another set of backing plates. But alas, I guess I will.
      Dan
      1968 Camaro v2
      Long Beach, Ca
      Dan, I had the same problem on my Nova. My left caliper is too close to the left (rear mounted) shock, the brake hose came off and immediately ran into the shock. I took the hose and spun it 180* so that it exits downwards, then I bent the hard line on the axle down under the caliper; the brake hose bends in a "U" shape and meets up with the hard line.
      Hope that helps.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      May 2002
      Northern California
      Why are you opposed to having a parking brake? GM backing brackets are cheap and readily available. Easy swap. never mind i actually read your other post. So you have a left and right bracket already?
      Tobin does have a bracket for the LS conversion. Give him a call, he has always been helpfull to us in the past. See if you can buy just the brackets. http://www.kore3.com/proddetail.php?prod=10277-01
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jun 2009
      Central FL
      Holy crap, I searched high and low on his Website trying to find a rear kit to see if they even made a bracket, I couldn't find anything. How in the world did I miss that.
      Gonna drop him an email tomorrow since it'll be Sunday. Thanks!
      Dan
      1968 Camaro v2
