02-05-2012 #1
Transmission fluid flow ? input,output
I have a 2004r in my 67 camaro and i am redoing trans lines to cooler. Is the lower fitting on the trans the output and the upper the input?
Should the output go to the lower fitting on the rad. tank and out the top to the external cooler then return to the upper fitting on the trans?
Just making sure. Thanks
Chris
