    Results 1 to 15 of 15
    Thread: Water Spots???
      Caledonia, MI
      Water Spots???
      We just moved into a new house. The water here is killing me. I can't dry a car fast enough to keep the spots off of it. These are not the kind of spots I'm use to, they look like I drew on the car with chalk. They are all over our sinks, well pretty much anything water touches. Whats really important to me is keeping the spots off our cars. I use a power washer, I'm wondering if anyone has come up with any good filtering idea to keep spots off.
      I was thinking of getting one of those in-line filters that are normally put under the sink and making something to mount two of them in-line before the power wash.
      Jason Mitchell
      1969 Camaro @ Dutchboys
      May 2002
      Southeastern WI
      Do you have a water softener? I know we have really hard water across the lake here in WI. Sounds like hard water spots.
      Jeff
      Dec 2002
      Lost Wages, Nevada
      Vinegar works well to remove hard water spots... but it reeks when you are done with the work.
      Mar 2003
      Kirkland, WA
      I like my Mr. Clean Autodry. My water isn't too hard here, but it drys spot free. I wash my car like I normally do to get the grime off, and then just hose it down and let it dry.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Caledonia, MI
      Thanks for the responses. We don't have a softener. We are looking at different filtering systems and softeners, not sure which is better for our needs. We need to do something though.
      I did however find one good use for this crap water. I finally got my front sub frame totally disassembled and I power washed 36 yrs of crap off this thing. I don't think anything has ever been off this car before. Shocks were still origanal and all parts had gm stampings. I did more cutting than unbolting.
      Jason Mitchell
      Nov 2004
      San Antonio, Texas
      outside water isnt softened even if you have a water softner..not good for the plants/grass...
      Jun 2005
      Greenwood, SC
      it kinda sucks to have to do it every time, but just so you know a claybar should take care of those spots...
      Nov 2001
      Sacramento Ca
      An inline filter system from your local Home Depot will help.
      Be sure to use both a "yarn" type and an activated carbon filter, with the yarn type inline first.
      Tony Langlois
      1966 Corvair Monza
      SoCal
      Mar 2002
      Redwood City, CA
      Quote Originally Posted by TonyL
      an inline filter system from your local home depot will help be sure to use a "yarn" type and activated carbon filter with the yarn type first.
      Wow.... Nice punctuation there Tony. I take it you were in hurry?
      Allen Ortega
      We use deionized water that runs through a special tank...from a company called dracor..you can wash a black car in the middle of the day in july and not dry it. Kinda expensive though, and the tank only lasts about 4to6 months.
      Caledonia, MI
      I think that I might just get that Griott filter looks like a nice piece.
      Anyone have any experience with whole home filtering systems vs. water softeners.
      Jason Mitchell
      Ontario, Canada
      A water softner will help. I'll bet when most installers put a water softner in your home, they don't seperate the outside taps.
      You could also try running a solution of dishwasher anti-spotting agent and water through the pressure washer when you rinse. I've had reasonably good results mixing a 1/2 cap of Jet Dry with a gallon of water. Then I run that through the pressure washer when I do the final rinse.
      Ken
      My other car is a Vega.
      May 2002
      Southeastern WI
      Quote Originally Posted by patriot68
      Ahh, that's why you have the garage hose bibb plumbed from the softened side.
      Jeff
      Oswego il
      i had a well @ my previous house, used two filters. one a yarn type on the outbound of the well pump to remove sediment, another "finer" filter prior to the water softener. used a special anode rod in the water heater. a little off subject.
      in my current home i have a sink in garage that runs softened water and can run a hose from it to wash the car in hot or warm water. very nice.
