    Thread: engine removal
      Mar 2011
      engine removal
      Is it necessary to drain the oil and trans fluid when pulling an engine and trans?
      Aug 2010
      Los Angeles
      I would just to save a possible mess and also it'll be easier when they are stationary.
      Mar 2010
      Okinawa, Japan
      I wouldn't worry about the oil, but definitely the trans especially if its an auto. Still seams weird to me that there aren't cheap plastic caps you can buy that would seal the output shaft once you pull a driveline...
      Oct 2007
      Atlanta
      Quote Originally Posted by carguykeith View Post
      There are caps for the tranny, there was one on mine when I bought it.
      Chicago suburbs
      I usually use a latex glove to seal the tailshaft in a pinch- it will usually last about a day. (you could always use that condom in your wallet too)
      May 2008
      Chicago
      Trans caps are nice but if they get knocked off on accident by possibly rubbing them against the core support, well then you have a mess. drain it and be doen with it then you have no worries. The engine oil can be done later.
      Jun 2006
      Santa Maria , CA
      It takes less time to drain the fluids then it takes to clean up a spill.
      Auburn, CA
      Quote Originally Posted by edog1 View Post
      Ain't that the truth!
      Tim Tracy
