    Results 1 to 10 of 10
      Jul 2011
      South Dallas, TX
      2x3 frame thickness question
      Im planning on building a complete frame chassis car and was wondering what thickness 2x3 tubing would be best to use?
      -Drew
      May 2002
      Northern California
      .120 wall is all we use.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      san diego
      Drew,
      Not trying to be a jerk, but if you are asking what thickness to use. maybe you should build your knowledge base on chassis design before you go and start to build one. It takes a lot of planning and engineering skills, not just the abilty to cut and weld.
      san diego
      Agreed, but not all cars need 2x3x.120 and some cars should use some 2x4x.120.
      The chassis that I am designing right now will be double tube with 1.75 DOM with .120 wall.
      Dec 2010
      I've got a decent amount of 2x3x.120 in my "floor." I used it for outriggers from my 2x2x.120 subframe connectors, and for a pie-cut-welded over-the-tunnel brace that I made (connects the subframe connectors over the tranny hump). It's worked pretty nicely so far, and I've been working the torsional resistance of the car pretty good lately...
      Jul 2011
      South Dallas, TX
      I know you arent trying to be rude but it did come across that way. I know more than enough on the structural design and engineering behind building a complete chassis. I just wasnt sure if many people were building their frames out of .085 on complete caged frames to save weight but bracing it right.
      Mar 2004
      Mid-Michigan
      On a drag only car .085 Chromemoly is acceptable, but for a street car that will see rough roads, potholes and train tracks you want to go with a heavier wall to carry that load. Saving weight is secondary in my opinion in order to make a safe and worry free road car.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      san diego
      Chromoly has a shorter life than a mild steel frame. Chromoly has fatigue issues. A race car is fine to use CM and save some weight but a street car that will see lots of miles should be MS.
      Rustburg, Virginia
      When you're shopping some places may call it out as 11 ga tubing.
      Jul 2011
      South Dallas, TX
      Thanks for the help I had a feeling I knew the answer to my own question, but I just wanted others opinions to confirm my suspicions.
