    Results 1 to 15 of 15
      Aug 2010
      Los Angeles
      Ridetech gas cap question
      Hey guys,
      I've got a 68 Camaro and recently purchased the ridetech gas cap kit when they were running the deal. My question is do I need to vent it? I've got a standard tank with a 350 SBC. New to this stuff and ya gotta start somewhere.
      Aug 2010
      Los Angeles
      Does anyone have a 68 with a standard tank?
      san diego
      Is the cap sealed? The tank needs to vent somehow.
      Aug 2010
      Los Angeles
      <<http://www.ridetech.com/store/1967-68-camaro-gas-cap-black-anodized.html>>
      Here is the set up and I purchased it with the optional vent kit. I was just curious if I needed to install that portion.
      san diego
      Does your tank have a vent?
      My stock gas tank (1965 ford falcon) has no vent but has a vent in the filler neck. You need one vent in the system, either the tank or the cap or the filler neck.
      Aug 2010
      Los Angeles
      Copy that. I'll take a look this weekend. Thanks guys.
      Central CA USA
      The cap is not vented. You need to add the vent fitting to the filler neck as supplied in the kit. Stock 68 tanks used a vented cap.
      Aug 2010
      Los Angeles
      Thanks David.
      san jose,ca
      Hi Dave qwk question if I ran a non vented caP on my 68 camaro would it make it seem as if I ran out of gas even if the tank was full?
      Eli
      68 camaro more plans then funds! lol
      http://s34.photobucket.com/albums/d1...view=slideshow
      san diego
      Quote Originally Posted by ROEINONDUBS View Post
      Yes, your pump would be trying to collapse the tank. Since you are pulling gas out of the tank you will need to replace that volume with air.
      san jose,ca
      Ok thanks I don't knw why they would have sent me a non vented cap
      Eli
      Lawrenceburg, TN
      I think all there caps are non-vented just drill a small hole on the top of the neck and tap it for a brass or plastic fitting and then run a hose to a small exit hole in the trunk floor, and its vented
      Central CA USA
      The cap itself is not vented, It may be a Motorcycle cap or some other application. Cars built after 1971 or 72 had Charcoal canisters for Vapor Recovery and the tank was vented to it, so they did not/do not need a vented cap. The cap did have a pressure relief in it though.
      san jose,ca
      I had purchased a stock style ss cap that was suppose to be for my car but it doesn't look like its vented, and after it went on my car had fule problems
      Eli
      Central CA USA
      Every SS cap I've seen is vented. There should be a pressure relief/vent valve visible right in the center of the cap.
