      Melbourne, FL
      Alum fuel line bender ??
      I'm probably going to need a tube bender for my fuel system. Sizes are 1/2 and maybe 5/8 for return .035 thickness. I found this one online at Harbor Freight. Looks like it should do the job. Won't be doing a lot of bends. Anyone have any thoughts on this bender or any others ??? I figure since I can bench mount it makes it easier. It can also bend smaller tubing.
      http://www.harborfreight.com/compact...der-99826.html
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Cartersville, GA
      I've never had any need to bend 5/8 aluminum, but 1/2 aluminum isn't a problem even for a hand held bender. Steel, maybe, but not aluminum.
      Joe Hinds
      Feb 2011
      Chico, CA
      I have a 5/8" feed line on my car. It was the hardest thing to find a decent bender that would do the bends I needed. Most benders do 1/2" or less. I ended up finding a spring type bender at home depot that is pretty awesome.
      http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
      The one I found in the store was a 4 piece with the 5/8" being the largest and was less than $20.00.
      Speedway motors will have the flange tool to do the AN fittings. Most other places only go to 1/2" as well.
      Good Luck!
      Jeff
      Melbourne, FL
      Quote Originally Posted by Blown73 View Post
      Good Luck!
      Ok I'll expose my ignoance now. Just how do those spring benders work??? I've seen them on other sites. But I don't get how to use them.
      Feb 2011
      Chico, CA
      Way easy. Even I could use it and it came out great.
      The tube goes inside the spring, and then you bend to fit, as you go. The Spring diameter doesn't change as you make the bend (if it does, it's negligible) so you can make 100* plus bends without messing up the tube. I was having issues of crushing the tube with a 5/8" bender, not saying they are bad, its more lack of experience on my end with them. Bending and installing the fuel line took me less than 2 hours start to finish and it looks great. I really can't say anything bad about the spring type bender....
      Jeff
      Feb 2011
      Chico, CA
      Jeff
      Melbourne, FL
      Ok that makes sense. I also did a you tube search and found a video of someone bending a tube useing these springs. Looks pretty simple. Will probably pick up a small piece to test my skills out on first.
