    Results 1 to 20 of 38
      Dec 2009
      Brunswick, GA
      Ridetech Spindle Machined Wrong?
      Hey guys...its me again with a question. Me and dad were trying to hook up Wilwood brakes to the ridetech spindles and the seal does not really seal on the back side. After looking at the stock disc brake spindle and the ridetech spindle, we have found the problem. If you look at the pictures of the ridetech spindle I've attached, about 1/16" is machined out at an angle where the seal would seat. I put the brakes on the original stock spindle and I could feel it seal when we when to pull them off. Not so with the ridetechs. If the ridetechs were machined on the edge like factory brakes or like they show in this picture, http://www.ridetech.com/images/category/tru-turn-d4.jpg, they would be fine. So is this a machining issue or do I need to try to figure out new seals? Maybe an offset seal of some sorts. Either way, the way they match up now, dirt and water will be able to get in the back side. Thanks guys
      1967 Camaro RS/SS - Project "Skunkworks" in Progress...
      Dec 2010
      Fredericksburg, VA.
      You need to contact ridetech!
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Dec 2009
      Brunswick, GA
      Thanks Steve, thats what I was figuring. They should know me by now...even though their stuff is really nice this has been the 3rd problem with my coilover kit.
      Indiana
      Can't really tell much from the pictures, probably need to see those spindles back to make sure there is no problem. send your Wilwood hub while you're at it so we can make sure everything is compatible. We can turn it around the same day. You'll need an rma number so it doesn't get lost when it gets to our building.
      What have been your other problems?
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      Henderson,NV
      My guess is that you need a different seal or you don't have a problem. Measure the distance from you bearing race to the seal lip and then transfer it over to the spindle for a measurment. The seal should ride nowhere close to the chamfer.
      Todd
      Central CA USA
      Is the seal flush with the edge of the hub? you didn't drive it all the way in did you?
      Indiana
      Coincidently, I just pulled a set of spindles off the shelf last night and installed a set of Baer brakes on a 67 Chevelle I'm working on at home. Everything fit perfect.
      Do both your spindles have the same problem? It's possible that one spindle could have been mis-machined...much less likely 2 of them were, and that they would have gotten in the same box.
      ...but I have seen stranger things...
      Bret Voelkel
      Oct 2009
      New Derry, PA
      Also wondering if the inner bearing race is fully seated in the hub? The seal lip really should go further up than the very edge of the register...
      Dec 2009
      Brunswick, GA
      Both spindles were the same way and I pressed the seal flush with the outside of the hub. If the seal would have been out of the hub say 1/16" that would have sealed I believe. With the seal sitting flush in the hub, the seal comes up to the edge of the angled corner when the bearings are sitting flush with the back side. I'll try to take some pictures tonight of the hubs but I'm going to call ridetech today to see. My stock disc spindles on the edge look like ridetech's website picture. These I have just look like they've had too much taken off the corner when they were machined. Either way, I'm going to call ridetech this morning and I'm sure I'll start disassembling them tonight to hopefully get them shipped back to ridetech asap so I can finally finish the suspension.
      Oct 2009
      New Derry, PA
      If you haven't already, I'd still check the inner race. It should be clear down against the lip Name:  3hub.JPG
Size:  62.5 KBin the hub. It still doesn't seem like the seal should be that close...
      Dec 2009
      Brunswick, GA
      I don't think its the seal though because everything fits perfect on the stock disc brake spindles. When I slide them on the stock disc brake spindles, it seals perfectly on the backside. Like I said though, I'm about to call ridetech.
      Dec 2009
      Brunswick, GA
      1) The rear 4 link set up cam with 2 different size springs so I had to swap one of them for the right size
      2) The ball joint holes didn't match up to the holes on the control arms so I had to ream/drill to make them fit.
      I know these are minor things and I am extremely happy with the product and what its going to do with my ride. Customer service at ridetech has been great as well. I'm just frusted right now because it feels like for every step I take, I have to pause 2 weeks before I'm allowed to take the next step (took 4 months just to get the 12 bolt from Moser). Dad has told me thats hot rodding. If thats the case I may change my signature to hot rod king
      Indiana
      Your Dad is right...there is a certain amount of "pain" associated with anything worthwhile. Although none of it is intentional, the wide variety of components built by a wide variety of manufacturers can sometimes cause incompatibility problems.
      And sometime things just get...screwed up.
      We build our own cars [and some customers] here so we see this on a daily basis...to the point where its now taken for granted. I've been known to say "its nothing that a 2 million dollar machine shop can't fix".
      A perfect example was the coilover system that we installed on Project X a couple of months ago. Check out post in the open forum, or the Feb. 2012 issue of Popular Hotrodding. Because of the way that the Corvette components were installed, we had to make a special spacer to get clearance between the front spring and the control arm. The original installaer did nothing "wrong"...just happened that his particular choice of installation created a problem for our particular component later on.
      And so it goes.
      Anyhow the point was not minimize you situation...that is a simple "go / no go" deal, and we'll fix it asap. Just trying to let you know that you are not alone in the stormy seas of hotrodding
      Bret Voelkel
      Quote Originally Posted by piratebaseball View Post
      Lol, be patient young one... (paint on then paint off). As you learn from experience, just about all of the same model cars are slightly different. Some by assembly from the factory and some just by plan use over the 40 something years. After market parts are designed to do there best to come as close to the standard deviation in sizing and/or machining as possible. Although the parts are superior in design and quality to the originals, they typically need some minor adjustments to fit for each case by case vehicle.
      Good luck, it will eventually get to the point you are looking for. And then you can enjoy the reward.
      Dec 2009
      Brunswick, GA
      Hey guys,
      Just wanted to give you an update. Got tired of waiting so I called ridetech today. They said the spindle was perfectly fine and that all of them were shaved that much on the large diameter part of the spindle. The person I talked said that they slid a wilwood brake on the spindle and it sealed fine on the back side. So now with that being said, has anybody installed Wilwood brakes on a ridetech spindle? These are the same wilwood brakes that Frank at Prodigy Customs sales on his website. If so, has anybody had a problem with the seal in the kit sealing? If anybody has the seal part number that you are using with no problems, please post so that I can check and see if the problem is that wilwood sent me the wrong seal. Thanks guys!
      Oct 2009
      New Derry, PA
      I still think you have a bearing issue. Looking at your pictures above, it looks like the ridetech spindle has a very large chamfer where the inner bearing sits. Pull the bearing out of the hub and make sure the face of the inner race contacts the step on the spindle. You won't see this with the bearing inside the hub, and there's no way to tell if the bearing is hitting the chamfer or the surface of the seal boss step. Also, did you double check to make sure the outer races in the hubs are seated all the way against the steps?
      The seal really should not be that close to the edge in any case.
      Oregon
      I'd be curious to know the relative depths of the bearing and seal counterbores to one another on your Wilwood hubs as it sounds like it could be something either related to the bearing as Ray suggests or just the seal postion in the hub relative to it. Considering how many of these Wilwood has installed and running, I would tend to think it's a bearing placement/seating issue along with Ray.
      Tobin
      KORE3
      It's what I does.
      Dec 2009
      Brunswick, GA
      I do not have the flanges in my hubs like you did in your picture and I'm pretty sure the race is down as far as it will go. Please look at my pics and see if any of you guys see anything unnormal. Thanks guys!
      Oct 2009
      New Derry, PA
      It looks like the hub has a definite stop for the seal, so I doubt you pressed it in too far. The seal lip does appear to be very close to the inner bearing race, which doesn't seem quite right.... I can't see form the pic whether the race is fully seated in the hub. I'd get in there with a dental mirror or hook pick and make sure the race is down against it's seat.
      Did you check the bearing fitment on the spindle? You said the seal worked fine on the stock spindle, so that seems to be where the difference is. Sorry to sound like a broken record, but the seal should not be so close to the lip that a 1/16" chamfer drops it off the edge.
      Jun 2009
      Piqua, Oh
      I am not familar with Willwood hubs... but, It looks to me that the seal has been installed backwards. Most of the seals I have installed had a flange on them and could only be installed one way. Hollow side out... that would move the sealing lip out, probably almost a 1/4".
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
