      Jun 2009
      From Wasilla, AK. Now portland, OR
      Global west A body front coilover kit?
      With the release of the global west extended travel coilover kit I have considered changing over to that setup. I wanted to know what anyone’sthoughts where on the kit. I know you can get qa1 or Penske shocks. I amrunning a SC&C front kit with the variShock dampers and spc springs. Is anyonegoing to be making a coil over to work with this kit also or going to be comingout with a kit like it? The only reason I ask is because I have the variShockson the rear also and wanted both ends to match in valving of the dampers and I knowthere are some suspension manufactures on here. thanks
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
      Des Moines, IA
      If you decide to use the GW kit we do offer coil overs that will fit:
      http://www.ridetech.com/store/coil-overs/
      If you don't want that much welding we offer a coil over kit that is bolt-in front and rear and provides 5+ inches of suspension travel:
      http://www.ridetech.com/store/1964-1...er-system.html
      (though the link above is a kit we do offer the items "a la carte" so you can pick and choose to build your ideal suspension system.)
