    Results 1 to 9 of 9
      Airbar Cradle INSTALL PROBLEM..
      So I went to install the cradle for the airbar 4 link setup and ran into a problem.. When I try and place the cradle in between the frame rails it doesnt fit inside of them very well AT ALL. I made sure the rear of the car is on jack stands and level but when I slide the cradle forward having the front bar hit the floor pan and line up the arch of the cradle with the arch of the frame it just doesnt fit. it sits cocked almost and the mounting points are about a 1/4 to 1/2 inch away from the frame Almost like something is cocked or something. I dont want to just screw it in and try to pull it into place as I am afraid of the thin frame metal pulling out. I also dont want to start HAMMERING away at it to bang it into place either unless that is what I am suppose to do???? I guess I would love to have reference points if possible off the tank straps or SOMETHING.
      I dont see any of the holes that the video on "48 hour camaro" video is talking about and the only other holes I see are a pair of them facing the ground from the frame BUT if I line those holes up to the back of the cradel then the bar would be going straight across where the tank straps are suppose to go... ANY TRICK TO INSTALLING THIS? Is it suppose to just slide in between the frame rails or does it need some soft blow hammer help? What should I reference it off of? I dont want to install it into the wrong place but I just cant make it go inbetween the rails without it being way off. Any help would be appreciated and THANKS IN ADVANCE!! BTW I have a MINITUB in the car... and the snubber is cut off per the instructions...
      Mark
      TOOFUN
