Results 21 to 24 of 24
07-06-2012 #21
Starting The Transformation
- Dec 2008
- Knoxville, TN
- 363
LGT-700 & Super Sport 700
Hi All,
We are now ready for mass production launch on the LGT-700 and it's KEISLER PerfectFit version, the SS700. This USA designed and built transmission is a major advancement over all 5 & 6-speeds available on the market now. You can learn about the product here: http://www.keislerauto.com/ss700.html
Here are some facts about the SS700:
1) DESIGNED PURPOSELY FOR MUSCLE CARS & CLASSIC FOR EASY INSTALLATION - the SS700 is designed specifically for our muscle cars and classics (unlike the TKO and T56, which are adapted for aftermarket from other designs). The cases, and shift system has been optimized for every popular classic GM, Mopar, Ford, AMC vehicle, PLUS some late model muscle.
2) ADVANCED SYNCHRONIZER SHIFT SYSTEM
The carbon kevlar lined blocker rings (single and double cone) synchro technology of the SS700 is far more advanced than the TKO, Richmond, Muncie, T10. Shift effort is less than any of these and the T56 6-speed. Additionally, the SS700 runs steel forks, bronze fork pads, billet synchro keys, bronze shift cup, cam roller bearing 5th/Reverse, and guide plate system single rail design. This is far more precise than the truck based TKO multi-rail which allows you to hit 5th as easily as 3rd when making a 2-3 shift. The SS is rated for 7500RPM shifts (TKO is rated for 6000RPM shifts, unless modified). All gears, including reverse are synchronized; no more clunk/grind going into reverse.
3) ADVANCED HELICAL GEAR DESIGN
All gears have undergone thorough design for gear tooth profile, sliding contact load and other critical paramaters. The resultant gearing design is high strength and quiet. All gears are CNC cut and CNC 6-axis gear tooth ground, then heat treated and shot peened. This contributes to quiet operation and high torque rating of 700LB-FT. The LGT-700 & SS700 are the ONLY aftermarket manual transmissions running GROUND TOOTH form gears.
4) WIDE RANGE OF BELLHOUSING ADAPTABILITY
Four (4) bolt patterns have been developed for the LGT & SS: 1) GM Muncie/T10, 2) FORD TOPLOADER, 3) FORD T5, 4) CHRYSLER A833
Four front bearing retainer configurations will also be supplied: 1) GM, 2) FORD, 3) CHRY LARGE, 4) CHRY SMALL
5) CHOICE OF RATIOS
Close Ratio: 2.66, 1.73, 1.33, 1.0, .68
Wide Ratio: 2.97, 2.07, 1.43, 1.0, .68 (available late 2012)
Optional 5th Gear Ratio, 0.80 (available late 2012)
6) HIGH QUALITY SHIFTER, Included
Features adjustable bias springs
Designed & made in America with product innovations that are 40 year advancements over other products in the market, the pricing point is set competitive to market
LGT-700 bare unit $2599 (3 shifter position available; shifter mechanism included)
SS700 PerfectFit bare unit $2899 (more than 20 shifter positions available; shifter mechanism included)
SS700 PerfectFit Kit $3499 (more than 20 shifter positions available; complete kit with new driveshaft and crossmember (where required)
AVAILABILITY:
The first couple hundred are already spoken for and are planned to begin production this month (July).
Legend Gear & Transmission is holding its 1ST Annual Summer Classic Car Show & Open House July 21st at its factory location at 820 Cochran Rd, Statesville NC. They will be giving tours of the manufacturing process. And there will be a giveaway for an SS700 transmission and a Keisler kit! Also, the Legend Gear Torque Sense Differential TSD will be given away. Come out and take a tour, have lunch, and enter to win a chance to the some product. Detroit Speed & Engineering, a neighbor of Legend, will bring some of their cars there. We will bring the Keisler XP HEMI Charger from Chop Cut Rebuild there. And LGT's new 2013 Boss Mustang Laguna Seca development car will also be there to check out. BRING YOUR CAR!
I will post more about the LGT product line in the sponsor section.
