    Page 53 of 59 FirstFirst ... 3 43 48 49 50 51 52 53 54 55 56 57 58 ... LastLast
    Results 1,041 to 1,060 of 1190
      Jun 2017
      Edgewater Co.
      I use these highly sophisticated quarter panel gauges
      CAD, cardboard aided design... I use it often and in many ways.
      Joe
      TEXAS
      Love the Q Panel gauges.... you should patent them! Awesome, simple, and easy to fabricate!!!!
      Burn em’ while we have em’. Fossil fuels and rubber tires till the end!
      Maryland
      Finally got the crudely welded together panels done. Pull some fiberglass molds off of these panels, then the part. Yahoo, then I get to do body work attaching them to the car.
      Ron Schwarz
      Jun 2014
      I love the fact that you are forgoing hours of metal finishing and creating fiberglass parts. Nothing wrong with metal but its nice to see a different process being done. The only thing that could top this would be a version 2 in carbon...
      Maryland
      The guy I used to pull the nose molds builds 80% of the dragster bodies in the country, all carbon. He recommended not doing them in carbon fiber. He explained about how strong carbon was in long flat panels, or in a tubular shape, but how weak it was on a complex shape with a lot of 90 degree angles. He explained how brittle it is, and how any shape corners in carbon will eventually crack. Considering he said my nose mold was the most complex mold he had ever done, with nothing but sharp corners, he recommended fiberglass parts reinforced in critical areas with Kevlar. So that it what I did, have to trust the pro's.
      Ron Schwarz
      Dec 2017
      Wow! This car is turning out great. I know I have watched a ton of fiber glass mold how to videos but I would love to see how you did it and what products you used. That quarter came out looking great.
      1951 Ford F1, 1967 RS Camaro, 1979 Firebird Formula, 1979 Trans Am/LS swap.
      Maryland
      Quarter panel molds are made, now finally on to the car. See if I can finish some of the bottom stuff, and send it to the powder coater.
      Ron Schwarz
      Maryland
      Got the last of the cage work finished, starting on tin work, filling in the little windows 1 at a time.
      Ron Schwarz
      The Netherlands
      Country Flag: Netherlands
      Looks great Ron!
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Feb 2012
      Central NY
      Wow that's quite a jungle gym!
      Jun 2012
      Australia
      Country Flag: Australia
      How are you intending to hold all the little sheet metal pieces in place?
      Maryland
      Silicone bronze
      Ron Schwarz
      Indiana
      Silicone bronze
      Are you going to leave it natural or paint over it? Either way, cool!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Maryland
      The body unbolts on this car, the chassis floor and all will be sent to the powder coater. The body may be as well, haven't decided yet. I will fill the voids in the floor with 1.75" rigid polystyrene insulation board, super light, and will make the floor flat. Then I will have some snap in carpet put on the flat part of the floor, like a boat.
      Ron Schwarz
      Oct 2014
      Cage work looks fantastic. This is a lot of fun to follow along with Ron. Thanks for all the detailed pictures/explanations. Such a cool build.
      1988 Mazda RX7 - Forged LS/T56, 76mm turbo, ProEFI, Ford 8.8 - Sold
      1965 Mustang Coupe - TT Coyote, TR6060, Haltech, big brakes, updated suspension.
      2007 Aston Martin V8 Vantage - Full bolt-ons
      2016 BMW 428iX GranSport - Stock...ish.
      Jun 2009
      New Hampshire
      Hey Ron, you have a tubing bender? Was wondering what you used to bend the cage and such. Thanks!
      Matt
      Matt from NH
      70 Camaro
      Project Wicked Pissa https://www.pro-touring.com/threads/...t-Wicked-Pissa
      Maryland
      I use a JD squared hydraulic/pneumatic bender, works pretty good.
      Ron Schwarz
      Sep 2007
      Buford, GA
      I haven't checked in on this one in a while, glad I saw it pop back up! I'm looking forward to hanging out with you and seeing the car hopefully sometime soon!
      Adam
      Adam
      1985 S10 - LT1 + T56
      Mar 2018
      ron, do you have any other pictures/info on how you mounted the body to the frame?
      Maryland
      I first made inner rockers with plates and nuts welded to the inside, then welded sleeves into the perimeter frame for bolts to go through. I'm sure their is an easier less labor intensive way to do it. but it works pretty good. The only bad part is the cage swells out at the A and B pillars, so you have to spread the rockers a bit when taking the body on and off. It comes off surprisingly easy though.
      Ron Schwarz
